Loss of MPG 06 LX, help!
Old Oct 26, 2009
indynic's Avatar
indynic is an unknown quantity at this point
Hey, new here. I have a 2006 Civic Coupe LX 5 speed, 58k. I am experiencing a loss of MPG. I used to average 35-36 MPG and now I am suddenly averaging 30 mpg. The only thing that is different is the air filter. I put in a cheapy STP Filter. Does anyone have experience with a K&N on these cars? Or is the factory Honda filter the way to go?
Could this air filter be costing me 5 mpg's?
Honestly, nothing has been done to this car on a maintenance level except oil changes religously. Is there any maintenance that should be done i.e. spark plugs, o2 sensors, fuel filter, tranny fluid etc.
Any help would be greatly appreciated!
Thanks
Old Oct 26, 2009
Re: Loss of MPG 06 LX, help!
factory filter is the way to go. K&N has very poor filtration. or if you dont mind the extra trouble, oiled foam filter by amsoil (if they make one for your car) is the best. has very good filtration and flow. needs to be cleaned and oiled every 6 months tho. but i doubt a new air filter would mess with gas mileage unless it was really dirty. at 58k, i would at least change the plugs. trans fluid is every 30k miles. maybe you just got a bad batch of gas?
Old Apr 7, 2011
Gunboy96's Avatar
Gunboy96 is an unknown quantity at this point
Did you find a solution to your problem? I have a 2007 Civic EX and I lost 7 MPG after routine Maintenance, oil Change, trans change, Tire Change.
I have changed the Oil and the Tires and the filter still no fix. Would an overfilled transmission be the problem
Old Apr 8, 2011
smoore08civic's Avatar
smoore08civic is an unknown quantity at this point
I don't know if it would effect your mpg but it is not good to over fill the trans.
Old Jun 24, 2011
eao_Bytor's Avatar
eao_Bytor is an unknown quantity at this point
I have an 06 civic with 144,000 miles on it. I used to get 38-40 mpg all the time. It is now down to 35-36 mpg. I have tried several different air filters and none of them have any effect on mpg. I am chalking it up to fuel re-formulation. I would typically see a drop in mpg in winter months but never this bad. I don't know what the refineries are doing different, but I don't like it. Must be the oil they skimmed off the gulf of Mexico after the BP spill.
Old Jun 25, 2011
TRIZ's Avatar
Doubt it.
You probably did something to change your MPG, like changed tires, or inflation- any one of them off, alignment, lowered?? Break pads, or over adjusted parking break and it may be rubbing... are you running AC or defroster now- windows down.. or parked with the engine running?
If not, then your O2 sensors could be getting wacky readings. Did you change intake filter, or cabin filters? I always fill up at the exact same Chevron, or at least Chevrons in general- a good idea as Chevron/shell/76/texaco all have different forumlations which can cause the difference.
Old Jul 20, 2011
anhkhoi84's Avatar
anhkhoi84 is an unknown quantity at this point
I got an 08 civic coupe ex and it has 93K miles on it already. Since I bought this car, I only fuel premium gas even though I don't have to. My MPG still the same so I think the gas has something to do with it.
SidCivic
Sep 12, 2015 05:28 PM
John2009
Sep 10, 2015 09:53 PM
tooly145
Sep 5, 2015 01:05 AM
frisbeeguy2
Jul 30, 2015 03:00 PM
alxz310
Jul 30, 2015 12:18 PM
