Engine Washing!! More Questions!
Old Jun 19, 2003
zinkyroo's Avatar
cool beans
zinkyroo is an unknown quantity at this point
I have searched and found that some people wash there engine while it is running and some say to clean it while it is off after it has cooled. Which one of these is the correct method? Also could I use the high pressure washer + soap at a clean it yourself carwash or not? Thanks!
Old Jun 19, 2003
2Hottie's Avatar
2Hottie is an unknown quantity at this point
You can use the high-pressure washer, with the engine degreaser-I use this on my truck all the time. Don't run the engine while you are washing it, run it immediately after to dry all the parts off quicker...
2Hottie
Old Jun 19, 2003
HomerSimpson's Avatar
I asked a similar question a while back and got several answers so I decided to talk to an auto detailer. First thing I was told is to make sure the engine is cool( If the water is to cold and hits the hot engine you can crack the block). Second I was told to cover the filter on my intake so water didnt get in it(I just tied a plastic bag around it). Next spray it down with Simple Green, put it on heavy where the grease and stuff is thicker. Let it sit for 20 to 30 minutes and go back and hose it down with a high pressure nozel. Repeat in areas that need it. My engine had a noticeable difference after the first time doing it.
Old Jun 19, 2003
zinkyroo's Avatar
cool beans
Do i need to cover the battery, and fuse box also?
Old Jun 21, 2003
zinkyroo's Avatar
cool beans
Old Jun 21, 2003
Mbow's Avatar
I wouldn't cover either of them. The batt definately doesn't need it and the fuse box doesn't unless you plan on being silly and blasting the water on it. Just don't directly spray the hay out it and you'll be fine. The whole engine bay does see rain ya know....
Old Jun 22, 2003
zinkyroo's Avatar
cool beans
Alright thanks
Old Aug 10, 2003
orion_squall's Avatar
so let's say mine is totally stock under the hood and it is automatic...
what should I cover exactly in order to wash it?
thanks
Old Aug 10, 2003
NeonImpact's Avatar
Forum Sponsor
thanks
pretty much nothing..
but if your careless, you might wanna cover up the fuse cover..
Old Aug 15, 2003
hoho's Avatar
hoho is an unknown quantity at this point
dont u have to cover the alternator and the distributor caps or whatever?
Old Dec 16, 2003
KeNsHiN's Avatar
LEVA
^no
thana
Jun 15, 2020 07:05 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
zack22490
Apr 29, 2015 03:17 PM
supercivic01
South
Nov 30, 2001 11:27 AM
CiViCPrAnInG2k1
Nov 2, 2001 02:49 PM
