Clearcoating a painted dash?
Old May 21, 2003
XxSoVeReiGNxX's Avatar
Exclamation Clearcoating a painted dash?
hey guys I just realised something.
Ok, so I finish painting my dash trims yesterday and decided not to clearcoat the 2 primers + 3 silver paint layers. I put together my dash, and then I started dusting and cleaning up the area.
I always read the directions, even after I've used it 5 million times. This time, "Not for use on ..., ..., glass, or painted surfaces" stood out to me. If I clearcoated the paint, then would I be able to use Armor-All or the type, on the painted trim right? But what if I decide to leave my painted dash as is, how will I clean it up without damaging the paint?
Thanks for your help, in advance.
Old May 21, 2003
FALKEN's Avatar
Civicforums Junkie
i would have cleared it even without thinking about the aftermath...
Old May 26, 2003
repoman2's Avatar
repoman2 is an unknown quantity at this point
Yep, always use a clear coat no matter what.
Old Jul 15, 2003
orion_squall's Avatar
ok,
anyone here has big knowlege about spray paint?
what brand of clear coat has the same effect of clear coat in shop. A shop painted my spoiler and I see their clear coat. It is very nice, very durable, just like a 0.1mm clear plastic covering the original paint, you can use finger nail to scrach it and the no trace will e left on the clear coat....
anyone knows a good brand of clear coat spray?
Old Jul 15, 2003
repoman2's Avatar
I have used the duplicolor paint and clear coat from pep boys and it has worked great. i have not used armour-all on it and probably would not but the duplicolor is a good clear coat.
Old Jul 17, 2003
wonderz's Avatar
wonderz is on a distinguished road
i uses the duplicolor clear coat and i often get the wrinkling problem (see the other thread)..but it didn't not wrinkle on my lastest project tho. even tho i always use the same kind of paint. hm...have to keep experimenting
Old Jul 17, 2003
hi
do not use laquar over enamel, you will have wrinkle unless you put many layer.
So, I did some research. For clear coating enamel, best is to use clear enamel. And best clear coat for part that will be touched scratched often, best is to use clear coat with ACRYLIC RESIN.
ok, here is the result, I simply used Krylon ACRYLIC CLEAR ENAMEL. The result is pretty great. However, I would suggest using it only ON PLASTICS, INSIDE THE CAR. I would not think it is good on fenders, hood etc. ALthought it says exterior/interior.
Old Jul 17, 2003
wonderz's Avatar
hm...what makes you think that its only good for plastic? if u can give me the reason, that will be great...
i always saw the clear enamel, but i don't think it says to top coat anything...so i thought it was just another paint that's not very protective...
Old Jul 26, 2003
Lucid484's Avatar
Lucid484 is an unknown quantity at this point
I just painted my trims and engine parts using dupli color.And it works great inside and out..My engine cam out perfect and the inside didnt...so i was like what the hell it was all wrinkly.And then I realised that i didn't wash the trim first...Becaus honda puts a wax film on all plastic parts it screwed my paint up.So I sanded down all the trim and wahsed it,then re painted and damn! they looked perfect.Duplicolor is great for painting trim.What i did was wash teh parts with dawn.put 2 coats of the adhesion promoter/primer on ,then 3 coats of the paint and 2 coats of their clear coat!about $10 in paint did my inside trim and engine..And oh yeah I only waited 5 min between each coat (i have no patience =) ) but it's durable and looks fricken awesome!
Old Jul 26, 2003
yeah,
acrylic clear coat enamel, use that. The reason I say ACRYLIC is better for updocoat paint on plastic is because ACRYLIC is a plastic resin and can form better bound on plastic. On outside of the car I will really not suggest any SPARY CAN. USE professional aerosol clear enamel, it will form a 0.5mm clear coat.
but must wait the paint to CURE totally if you can't bake the paint! (5-6 days) if you want best result. because it will lift your paint. For exemple, your primer is black and you paint your piece silver, if you don't wait it to cure totally, clear coat will lift the black color.
what I refer here are spray cans. I don't know how professional clear aerosol works, but I know those are the real good stuff if you have equipment and access to those paints.
h4ldol
Apr 24, 2017 08:16 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
Sep 27, 2015 11:33 AM
General DIY
Sep 25, 2015 08:02 PM
Klame9420
Sep 18, 2015 12:37 PM
