HOW DO I TAKE PAINT OFF
Old Jan 16, 2003
Unomyname's Avatar
Unomyname is an unknown quantity at this point
i painted my trim peices like the diy...now i have a dash kit and i need to remove the paint on my air vents...how can i go about doing that??
Old Jan 16, 2003
Grey's Avatar
DIY King
Lacquer thinner works, but it also eats plastic. I would try lacquer thinner and a toothbrush. Otherwise I'de try using an airgun that shoots little particles and maybe try some small plastic particles to strip the paint off. You'de have to have this equipment though.
Old Jan 16, 2003
MaxPSiLX's Avatar
MaxPSiLX is an unknown quantity at this point
The only bad thing about using laquer thinner is that it can dull the finish on your vents...but that's a chance you take when you paint things.
Old Jan 16, 2003
666's Avatar
666
666 is an unknown quantity at this point
A very, very fine sandpaper may work also, like a 400 grit or higher.
Old Jan 16, 2003
flotsamm's Avatar
Maybe carb cleaner? To take off anodized colors off of alloy, EZ Oven-Off in the yellow can works well. Not sure if I'd try either of these on your air vents.. but if your daring enough [IMG]i/expressions/demon.gif[/IMG]
EDIT: maybe some brake fluid.. dunno. I dont recommend any of the above. BUT, if you try it let us know!
Old Jan 16, 2003
Grey's Avatar
DIY King
Yeah, I hear that brake fluid takes off paint. That might work.
Old Jan 24, 2003
sg2kca's Avatar
sg2kca is an unknown quantity at this point
acetone (nail polish remover)
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
carid
Sep 28, 2015 10:13 AM
Sep 27, 2015 11:33 AM
speedlever
Sep 24, 2015 07:18 PM
