Cleaning Engine Bay
Old Jan 3, 2003
TiM3's Avatar
TiM3 is an unknown quantity at this point
Cleaning Engine Bay
Do you guys know the best way to clean out the engine bay? IS it safe to take a water hose to it or am I just going to have to go in there with a wet cloth?
Old Jan 3, 2003
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
simple green and a hose
Old Jan 3, 2003
JDMCIVIC's Avatar
JDM WHORE!!!
JDMCIVIC will become famous soon enough
I use engine cleaner and degreaser and steam power!!
Old Jan 3, 2003
BigHippo22's Avatar
BigHippo22 is an unknown quantity at this point
Hose and water is safe as long as you don't squirt it right in the intake
Old Jan 3, 2003
robbclark1's Avatar
Retired suspension supermod.
Quote
[hr]Originally posted by: 4drcivic2k1
simple green and a hose[hr]
Hell yeah. Just don't drive for a few hours to let it dry.
Old Jan 3, 2003
drakeo's Avatar
drakeo is an unknown quantity at this point
use water sparingly
Old Jan 3, 2003
SLAMMED01CIV's Avatar
SLAMMED01CIV is an unknown quantity at this point
Dude, I go to the local car wash and use the engine degreaser then spray it with the high pressure hose. All good.
Old Jan 3, 2003
nongv's Avatar
nongv is an unknown quantity at this point
what about all of the electronic stuff in the engine bay? wont they get wet.
Old Jan 3, 2003
Nuts's Avatar
Nuts is an unknown quantity at this point
Quote
[hr]Originally posted by: nongv
what about all of the electronic stuff in the engine bay? wont they get wet.[hr]
bag it, just put a plastic bag over em
Old Jan 3, 2003
CarbonFly's Avatar
There are companies where I live that will do a full car detail cleaning including the engine bay for $125. Great if you are taking your car to a show.
Old Jan 3, 2003
dragoon's Avatar
Quote
[hr]Originally posted by: robbclark1
Quote
Hell yeah. Just don't drive for a few hours to let it dry.[hr]
i hear it's better to run the engine a while so it will dry quicker
Old Jan 3, 2003
TiM3's Avatar
Thanks. I'm not sure which one of you guys are correct about the drying part though, I guess I'll just go to the car wash and ask how they dry?
Old Jan 3, 2003
PwN3d's Avatar
PwN3d is an unknown quantity at this point
if you have an aftermarket intake, take off the filter as it is exposed. then start the car, pop the hood, and grab the hose.
Old Jan 3, 2003
Grey's Avatar
DIY King
Me and Krepoort did this...
- turned on the car for a while to warm it up
- spray everything down with water, avoiding the fuse box and battery terminals
- spray Simple Green all over the engine bay, especially the grimy spots
- use a clean rag to rub down the stubborn areas
- let everything sit for a little while
- spray everything down with water to get all of the grime off
- repeat the entire process (including warming the engine) to remove more grime
I guess you could use a plastic bristle brush to get certain places clean. Maybe an old toothbrush as well to reach the corners. Just avoid getting the fuse box soaking wet and avoid getting the battery terminals soaing wet. Do not spray directly into the intake. Also avoid drowning the alternator. I don't think it matters how much you spray, but high pressures might damage certain things. Just be gentle and your engine will love you.
Old Jan 4, 2003
TiM3's Avatar
Sounds Good
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
superstanko
Apr 28, 2015 04:38 AM
Dmitri
123
Oct 13, 2005 08:01 PM
supercivic01
South
Nov 30, 2001 11:27 AM
antidote11
Nov 27, 2001 10:46 PM
