Door Edge Guards ruined paint!
Old Dec 28, 2002
Well, after six months I decided to remove those door edge guards on the side of each door. Most of the dirt wiped away, but on one door there is a really bad mark along the side that I can't get off. I got the glue out already, but the hazy stuff won't come out. I know it's hard to explain. The paint feels smooth, so I'm wondering if it got damaged when the dealer installed them a while back. What should I try to fix the paint with?
Thanks
Old Dec 28, 2002
Ed's Avatar
Ed
If you think it's a sirface problem, try a clay bar, it more or less removes everything from teh paint.
Old Dec 29, 2002
2Hottie's Avatar
2Hottie is an unknown quantity at this point
That happened to my bro's car...he did the same thing and he is planning on getting the door repainted when he gets his body kit...plus, he has a lot of rust on the inside bottom of his door, so he has to get that taken care of...I think clay bar would be a safe and good bet....
2Hottie
Old Dec 29, 2002
Hey 2 hottie, I tried some of the meguiars "clear coat" cleaner and it worked pretty well. There are still some marks, but only if you look up close. [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Dec 30, 2002
2Hottie's Avatar
Quote
[hr]Originally posted by: gearbox
Hey 2 hottie, I tried some of the meguiars "clear coat" cleaner and it worked pretty well. There are still some marks, but only if you look up close. [IMG]i/expressions/face-icon-small-wink.gif[/IMG][hr]
Thats great! I use some of that stuff too when I do a good detail...well worth the money and does a great job!!! Congrats!
2Hottie
Old Dec 30, 2002
showoff's Avatar
showoff is an unknown quantity at this point
Try 3m finecut rubbing compound! If its just an adhesive it most likely bonded to your clearcoat, but it can be removed with a mild abrasive. Just work the compound in until it dissipates the haze. It should work, good luch
Old Dec 31, 2002
Thanks for the replies
Old Dec 31, 2002
2Hottie's Avatar
Quote
[hr]Originally posted by: showoff
Try 3m finecut rubbing compound! If its just an adhesive it most likely bonded to your clearcoat, but it can be removed with a mild abrasive. Just work the compound in until it dissipates the haze. It should work, good luch[hr]
Does that stuff work well to get out small scratches and stuff?? I am dying to try it....
2Hottie
Old Jan 1, 2003
Pinoy3LeR's Avatar
Pinoy3LeR is an unknown quantity at this point
yeah 3m fine rubbing compound will do the job after that apply wax
FILIPINOSTYLe
GotSiR
Jun 23, 2016 04:06 PM
ballmich
Jul 9, 2015 11:59 AM
BootyDo
Jul 7, 2015 06:06 AM
