Removing Strip from Sides
Old Oct 13, 2002
KocKDieselUMD's Avatar
KocKDieselUMD is an unknown quantity at this point
I have a Titanium 2002 Civic and want to remove the strips that run through both sides of it... THey're black and theres two small ones in each side... they're the ones that run horizontally from taillight to ur headlights. I've noticed that they seem like stickers or sumthing of the sort since their edges are raised
Anyone know how I should go about doing this without damaging my car?
Old Oct 13, 2002
white2K2EX's Avatar
I sure wish my car was newer
Its just a sticker. So peel up one end of it, and pull. Then wash your car and wax it. I'm removing mine when I get my spoiler which should be in a few months here, so if you're really worried about it I'll update. Its like shaving your emblems, but easier. BTW - the 'strip' is called a pinstripe.
Old Oct 13, 2002
Awesome... I thought It should be pretty easy and it makes the car look a lot "cleaner"
Thanx for the info! I'll prolly get mine removed before then so I'll let you kno if I run into any problems!
Old Oct 13, 2002
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
if you have an extension cord, I recommend you take a hair dryer or heat gun and heat up the strips as you pull them off. that way you won't have any sticky residue left behind. also makes it easier to pull off. if you do encounter residue, just use wd-40 to wipe it off and wax the area afterwards.
Old Oct 13, 2002
Sound's good, I'll make sure and do that cuz I've spent a lotta time getting sticker residue out of old car windows!
You say WD-40 as in the oil? I didn't know that was safe to use on paint, thought it might stain or sumthin... but I've never tried it so I wouldnt' know... I just wanna make sure it's not some other thing and I end up using oil where I shouldnt!
Thanx for the ideas!
Old Oct 14, 2002
Mex's Avatar
Mex
yeah, WD-40 is safe. I used it after removing my dealer sticker.
Old Oct 14, 2002
white2K2EX's Avatar
Goo-Gone would also work to remove the residue. But it most likely won't require that.
Old Oct 15, 2002
Seems like it should be much easier than I expected! That's what I like to hear! [IMG]i/expressions/beer_yum.gif[/IMG] Cheers for the advice!
GolNat
Suspension DIY
May 12, 2022 06:49 AM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
mohawkboom
67
Aug 25, 2015 12:28 AM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
