Engine Cleaning
Old Jul 4, 2002
LiKEaFeRiO's Avatar
Engine Cleaning
I've search for this topic and others like it and I couldn't find an answer. I think many of the good threads were deleted because people like Civicdude said to search for "engine cleaning" and there are no threads on it.
I understand the idea of washing and degreasing the engine but I still have no idea exactly what to keep covered while doing it. My car is all stock under the hood and I'm just planning to use a regular green garden hose with my thumb on it to get better pressure. So what exactly should I be covering??
Thanks.
Old Jul 4, 2002
civicdude's Avatar
Start the car...Tell you the honest truth....you dont need to cover anything. What I do is I spray the fenders, hood, front end, and windshield down with water...Pop the hood. Shut off the engine. Spray down the whole engine with gunk or simple green diluted with water. If it is really filthy go over the engine with a wet towel or was mitt. I also spray under the hood and wash that down with the wet was mitt too. I then start the car again and hose the under neath of the hood and the engine compartment. After all the soap and chemical is hosed off I let the engine run for 5 to 10 minutes and I then shut the enigine off, and wipe off the exccess water with a dry towel. I then spray the entire engine down with a silicone based tire shine and wipe the excess off after ten minutes of it drying. Bam your done with the engine compartment. Always make sure the engine is running when you are spraying water on it. AS for searching:
1 post on engine cleaning
2 post on engine cleaning
3 post on engine cleaning
4 post on engine cleaning
5 post on engine cleaning
Wow thats strange how I found all these posts on engine detailing. All I put in the search was the word "ENGINE"...Try harder next time.
Old Jul 6, 2002
dragoon's Avatar
do you spray stuff even on the electrical components?
Old Jul 6, 2002
civicdude's Avatar
Spray the entire motor down. I just did my dads car, he has a 2002 lx coupe. I sprayed the entire motor down with the degresser and then started the car and hosed it off. You will not have a problem, if you are worried about spraying certain things, then cover them.
Old Jul 8, 2002
2001CIVICLX's Avatar
2001CIVICLX is an unknown quantity at this point
Use this stuff...
CD2 ENGINE CLEANER, should have it at your local autoparts store... It works wonders...
Old Jul 8, 2002
civicdude's Avatar
You dont even need the CD2 stuff. You are only buying a name. Use the simple Green or Engine gunk and tire shine to make it shiny....
Old Jul 8, 2002
Civey's Avatar
Civey is an unknown quantity at this point
Simple Green is what we use in the shop. Works the best for the price.
thana
Jun 15, 2020 07:05 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
SugarRay
Bolt-on Engine Performance
19
Jan 8, 2002 02:55 PM
supercivic01
South
Nov 30, 2001 11:27 AM
