Best item to dry car
Old May 7, 2002
Jadastyles's Avatar
Jadastyles is an unknown quantity at this point
which cloth would be best to dry my car, Im not sure what to use since im very paranoid about scratching my car,and which cloth i should stay away from. Also i would like to know if its better after you DIY wash your car to dry at the car wash or take it home and let it air dry then wax it, dont flame me im a noobie, i also tried search
Old May 7, 2002
trevor's Avatar
trevor is an unknown quantity at this point
NEver Ever EVER let your car air dry (unless you love them beautifull water spots).....
Always make sure you dry your windows also,......
I just use a 100% cotton expensive towel,.....very soft,......and dry ASAP after washing,....
some peeps may not agree,....but...If you want it always looking killer,...dry asap,....
anyway, peace
also, when I dry my car,..I dont do any kind of circular shapes when drying(or washing).....
I lay the towel on the car and grab one end, then drag it length ways across the car,.....top and sides..
then in any case if you do get swirl scrathes,,, you cant notice them as much,...cause they all go in one direction,...
Old May 7, 2002
civicdude's Avatar
I agree with not letting your car air dry. The only way I would do that is if you use a product that is soapless like 3M soapless car wash, but other than that make sure you dry your car immediatly after washing. Those water spots are a pain to remove. I usually use the California water blade first and then get the rest of the water with a chamois. I then wipe the door jams and wheels and wheel wells out with another towel, never use the chamios.
Old May 7, 2002
TwilightX's Avatar
TwilightX is an unknown quantity at this point
I'm all about the water blade! I just gotta get one instead of borrowing krepoort's (thanks brotha!)
Old May 7, 2002
xHoteKx's Avatar
Tomotor
xHoteKx has a spectacular aura aboutxHoteKx has a spectacular aura about
i used to dry with terry towels. but it takes so d@mn long! then i invested in a absorber. wow, that thing dries my car so fast! i also wash and dry in sideways motions. never in circle. for waxin, i do circular motions too, but is it ok if i mak sideways motions?
Old May 7, 2002
SpacemanBob's Avatar
SpacemanBob is an unknown quantity at this point
Buy "The Absorber", dunno what the website it, but essentially it is a chamois (shammy), but made of synthetic materials, so it can't scratch your car
ALSO if you buy cotton towels (I use them to buff off wax, be SURE of the following 2 things!
1. The towel is "Made in USA", otherwise it might not be 100% cotton.
2. Cut off the sewn edges! These could potentially scratch your car also
Old May 7, 2002
my2k1vic's Avatar
my2k1vic is an unknown quantity at this point
i don't know if any one else does this but i use a piece of leather. the leather is soft and absorbs the water nicely and most of all leaves no lint! it also does not scrach the paint
Old May 7, 2002
xHoteKx: I dunno about other waxes, but the instructions on the Zaino bottle say to do all horizontal surfaces of your car front and back and all vertical surfaces up and down to make the light shine off of them better....
Old May 9, 2002
luldude's Avatar
luldude is an unknown quantity at this point
A cheap way to dry your car is to just use a cotton towel. The only thing bad about the cotton towel is the lint it leaves. As, to avoid using a bunch of towels, take your hand and slide most of the water off before you try and dry it. This will keep you from using a bunch of towels and a bunch of laundry too. gl
Old May 10, 2002
2Hondaz's Avatar
2Hondaz is an unknown quantity at this point
I agree with the absorber or the cali blade/absorber methods....By far better than a chamois (which IS a piece of leather) and anything else you could use. Always wash with a soft wash mit.
Old May 12, 2002
showoff's Avatar
showoff is an unknown quantity at this point
Before I even start drying my car I rinse with a direct stream of water w/o a hose nozzle and that seems to leave my car with less pellet water as it sheets off excess soap, then I use the california water blade to quickly remove the majority of the water, after that I use the absorber on any bent surfaces e.g. on top of the bumper between the trunk or in between my body kit and chassis, finally i finish drying with a micro fiber towel.
Old May 13, 2002
wonderz's Avatar
wonderz is on a distinguished road
I use some expensive paper towels...the ghetto way
That way, whenever one gets dirty, I just get a new one...help prevent rubbing dirt (maybe from under the car) into the paint.
Old May 13, 2002
TwilightX's Avatar
I just used the absorber recentky, and DAYUM! That thing is great! Better than the California Waterblade!
T-X
Old May 14, 2002
civicdude's Avatar
<< I use some expensive paper towels...the ghetto way
Are these paper towels made for the paint surface?? If they arent you will scratch your paint. Check the paint to see if you usee tiny scratches in the paint, if you do stop using your paper towels. The only paper towels I would reccomend to use on the paint is Scotts Towels. They come in a Yellow box and can be bought at any auto parts store. They usually come in a box of $200 for $10. I keep one in my trunk at all times.
Old May 14, 2002
Ya civicdude is right...... Paper towels = paper = wood, like from trees...... would you rub a tree branch on your paint? I didn't think so. Any paper product is a bad idea.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
LionSpratt
Apr 26, 2015 01:02 PM
jstotts
Apr 20, 2015 09:32 PM
JDog2001CivicEX
Nov 2, 2001 02:27 PM
