How To Get Rid Of Bird Poop?!
Rep Power: 0 How To Get Rid Of Bird Poop?!
Well it's been around 60 hours since I got my car... and I come out to just stare at my car again and I find a BIRD SH*T! Well, first bird poo to be found. All dried up. I got a wet napkin and wiped it off and it left one of those... tiny scratches that you can see in the sun light.
What's the proper way to take off bird poop?
Rep Power: 350 I have used Meguiars Quick Detailer to get it off make sure you cover the area you need to clean good and let it sit for a few secs maybe a min or two to break it up then take a clean micro fiber or terry cloth and wipe GENTLY and then turn to clean side and clear off and i would go again to make sure...its safe to use w/o water or if you wish you could always wash that area to remove the crap...up to you
TEAM REVolution
TEAM REVolution
Rep Power: 372 << I have used Meguiars Quick Detailer to get it off make sure you cover the area you need to clean good and let it sit for a few secs maybe a min or two to break it up then take a clean micro fiber or terry cloth and wipe GENTLY and then turn to clean side and clear off and i would go again to make sure...its safe to use w/o water or if you wish you could always wash that area to remove the crap...up to you
TEAM REVolution >>
Red Dragon is right on the ball. Do not use a napkin ever on the paint, you probably caused the scratches with the napkin. Always use a damp clean towel and either wash the area with a hose and soap or soak the area with detailing spray, let it soak and get soft and then wipe it off with the towel. The light scratches you see now will require you to use rubbing compund to remove them.
bolt-on-bandito
Electrical
32
01-15-2020 03:25 PM
Touge
09-22-2015 11:55 PM
Touge
Ottawa
09-22-2015 11:52 PM
thaler4cuse
09-07-2015 08:25 PM
Touge
09-01-2015 11:25 PM
