Stupid question about Cleaning Engine Bay with oil leaks?
Old Sep 17, 2005
streetglower's Avatar
This is probably a stupid question, but I will ask anyway, my dad drives a 2000 Kia sportage and his engine bay is filthy as hell and I was going to clean it but his valve cover is leaking, and his head is also leaking oil. Would it still be ok to clean the engine with oil leaks?
Old Sep 17, 2005
civic01vtec's Avatar
yeah, that is fine......there is no way any water will get in under the valve cover.
btw.......a 2000 with a oil leak from the valve cover....only a kia
Old Sep 18, 2005
its fuked up, the valve cover is leaking, the head is leaking, the oil pan is leaking, the tranny is leaking, and I wouldnt be suprised if the rear main seal was leaky.
Old Sep 18, 2005
CraigW's Avatar
"Engine-Brite" & foamy engine brite will help cut the oil off. I would try to not get it on too much plastic though, concentrate on metal. I used to use it, pretty safe.
Old Sep 18, 2005
I used the foamy engine brite to clean his engine. I like that stuff, but it leaves the white film on everything. So I used the CD2 engine detailer when I was done.
LionSpratt
Jan 29, 2017 11:07 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
superstanko
Apr 28, 2015 04:38 AM
Maximus
Bolt-on Engine Performance
Nov 18, 2001 03:55 PM
trevor
Nov 16, 2001 05:02 PM
