my absorber has dried out!
I left the absorber outside to hang dry, it is now like a board and dried
Do you store it wrapped up wet??
When I dried my car, it is really good at drying like ya'll said, but it sticks to the car sometimes.....
i left mine a little damp in the container. and it started to grow mildew because it got really warm in the garage. what should i do to get rid of the mildew and get rid of the smell. should i just bu another one?
Just throw it away and get a silicone wiper blade. Or let the car air dry if you use indoor water. I would never wipe my car with that absorber.
get a new one?
or you could just soak it and itll be like new again.. mines dried out after i left the cap off a few times, no big deal. and wiper blades suck ***, absorbers are good because your actually polishing the finish
Originally Posted by ctx66
get a new one?
or you could just soak it and itll be like new again.. mines dried out after i left the cap off a few times, no big deal. and wiper blades suck ***, absorbers are good because your actually polishing the finishLast edited by rckdrmr; Jul 17, 2004 at 07:44 PM.
President
NO don't get a new one.. this always happens...
After a wash do what Ramone said.. Rinse is squeeze some of the water out and put it back in the case with the top on.. it will be ready for the wash (in the next few days.. IT will not mildew.. unless you leave it for like years..)
If you have to wash it and put it in the dryer.. then soak it in water let it sit and use...
dam man i wash my car every 2-3 days.. live and learn
President
what.. ok i'be gone through soo many chamois.. and some were really good but they don't even compare the the absorber.. its like a chamois but different material.. yes you can pick them up just about anywhere. about10bucks... the first few times it sucks but once its broken in... it works perfect for drying your car etc..
Originally Posted by alienmeatsack
Ok... stupid question but what are you guys talking about? A Chamois? Is this something i can get at say walmart or target or something?
its very similar to a swimmer shamee if youve heard of them.. actually thats what i used before the absorber came out.. a friend whos a swimmer said it works great.. tried it.. and it did.. its sort of like.. a rubber towel that can absorb a ton of water..and then squeeze out and be like new/dry again
I wanted to thank you guys for bringing this wonderful tool to my attention. I picked one up and have fallen in love. I think i am going to get a second for use in the house for spills, drying my dog after a bath etc. This thing is so cool!
I forgot to mention that I did some testing to see how much water it would hold.
So, I got a large measuring bowl, set it aside. Then I did several experiements to see what happened...
first I got it wet, squeezed out every bit of water I could so it was damp but not overly wet, like for storage.
Then, I got it as wet as it would handle, let excess water drip off until it stopped dripping and wrung it out into the measuring bowl. First try I got 1 and 1/2 cup water.
Second try, same as above, got abut the same, just over 1 and 1/2 cup water.
Third test I let it soak for 10 minutes first, pulled it out and let it drip until it stopped dripping, then wrung it out again. This time I got just under 1 and 2/3 cups water.
Very cool. That is about 3 times what my chamois of the same dimensions would hold on a good day.
Now thats what I call good shizzle.
when you get done with it, squeeze all the water out. then, hang it on a pant hanger (the one with two clips) and let it dry. then when it's all dry (you'll feel it) fold/roll it up in the tube. i don't like to put it away in the tube after use, because it may not completely dry correctly and may get a mildewy smell. every now and then, toss it in the laundry to get it clean. it i've had mine for two years, and it only keeps getting softer/better!
martinsmartin
Aug 15, 2015 07:34 PM
