can some help me out on windows cleaning
can some help me out on windows cleaning? i tried so many brand for window cleaning, but no matter how hard i clean them, i can always see like this greesy layer inside, i dunno why, but it just not coming off. can someone help me out here serious f*** up
Ive used Windex Automotive Window cleaner, I think that is what it is called.. Windex something or other, not the household stuff cause I think that will f*ck with tint. I just use a newspaper, and get a streak free shine.
this is the best way to clean the inside of your windows (works for me). spray the window (i use eagle 20/20 vision window cleaner) and make sure you use a wet napkin and go over the entire window to clean off the film, etc... next (with the window still wet) use a small squeege and run it across the window and use a dry towel to wipe it off the excess. this method gets results by not having to see the circles and spots you've missed by wiping and smearing.
Welcome To Prime Time, BITCH!
e-married to daydreamer
well use a glass cleaner and wipe all the residue off, but after youre done try this:
take a clean, dry cotton terry and again wipe away where you cleaned up on your windows.
this should get rid of that greasy look. possibly.
No matter how hard you try Glass cleaner will not remove that stuff. What you need to do is apply some Clear Vinegar to a rage and wipe it into the glass. I suspect this is the back window we are talking about. I have had many civic's come to my detailing business with the same problem. I cleaned the whole window with Vinegar and then with a Ammonia free glass cleaner, and wiped the glass down with a micro fiber towel. The customers that had this done have not had the problem since.
Thanks.
i remember talking to the salesman when i picked up my civic in 02...he said the plastic they used in the car gives off this residue that sticks to the windows when it's hot...when i got my windows tinted, they cleaned it off
Martinez8o5
Jul 31, 2015 10:58 PM
breanna_17
Jul 21, 2015 04:01 PM
Jul 12, 2015 11:54 AM
ballmich
Jul 9, 2015 11:59 AM
