SOHC D17Ax non-VTEC - VTEC Engine Swaps Post information/questions about non-VTEC VTEC D-series engines here.
D17A2 Auto Engine to D17A2 Manual Body Swap
Old May 15, 2018
Auae85's Avatar
Auae85 is an unknown quantity at this point
New to this forum but a long-time member of others,
I have a 2002 Civic EX with D17A2 VTEC and auto trans. Car has a salvage title due to a hit and run and a small fender-bender 10 days apart - body shop put both claims in at once. Anyway, damage was cosmetic and mechanicals are perfect. Unfortunately, the trans has died. Local garage has a 2002 Civic EX with D17A2 VTEC and 5 speed with a bad engine. Body is practically perfect.
What would I need to change / acquire if I put my engine (from auto trans car) into the manual trans body? I know I need to swap the flywheel / flexplate and such. Any other parts?
Thanks in advance.
Old May 16, 2018
Colin42's Avatar
Re: D17A2 Auto Engine to D17A2 Manual Body Swap
Possibly throttle body as well?
If you can have both cars next to each other when you do the swap that would be ideal so you can make sure everything that needs to be swapped over does
Old May 16, 2018
D17VTECPOWER's Avatar
D17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of light
If you are asking what’s different about an auto and manual trans engine, the answer is basically nothing. The engine’s wiring harness is different, and the flex plate would need to be changed for a flywheel. That’s about it.
Old May 16, 2018
The throttle body is the same.
Old May 16, 2018
Slumpertcivic's Avatar
Coupe vs sedan have different drivers side engine mount arm.
Swap entire throttle body (different) and sensors, no reason to possibly carryover a issue.
Swap entire engine wire harness,
Consider how easy it will be to replace all the seals while engine is out.
Old May 16, 2018
When I put a MT engine in my AT car, I didn’t swap the sensors or throttle body. I just put my flex plate on the engine and used my OEM wiring harness, and it worked fine.
Old May 16, 2018
I would suggest changing all the gaskets, as well as the timing belt, tensioner, and water pump before you install the engine. Much easier with the engine out of the car!
Old May 16, 2018
Colin42's Avatar
The same car with all these issues you keep posting about?
Old May 16, 2018
Colin42's Avatar
The IAC is definitely different
Old May 16, 2018
Yes. However, the bad PCM that is causing the issues has nothing to do with this being a manual trans engine.
Old May 16, 2018
It may be. I didn’t see a difference though, and both throttle bodies worked interchangably, so I don’t know.
Old May 16, 2018
Colin42's Avatar
2 different part numbers...
They're not going to make 2 different parts just for fun.
OP
seals, headgasket, timing belt, water pump, and tensioner are all a good idea to do while the engine is out of the car as other people have mentioned.
Obviously flywheel, clutch etc.
The IAC is definitely different, Pretty sure the throttle body is as well so just swap the entire thing over.
Depending on how the old engine failed, you make want to keep it for extra parts.
Same with your old shell, pull of as much as you can keep and then sell/scrap the rest.
Old May 16, 2018
OP
I stand corrected. I looked at a parts diagram, and the IACV is different. Not sure why it worked for me, but it is different. I learned something new.
Old May 16, 2018
piano55man's Avatar
piano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of light
i would highly suggest doing the gaskets and timing belt while the engine is out of the car.
get a new clutch and flywheel while it's all apart as well.
good luck
Old May 16, 2018
Auae85's Avatar
Thanks for the replies. BTW, both cars are 4-door sedans. MT car's previous owner apparently let it run low on oil and ruined the engine. It will crank and run, but sounds like crap. I have 206K miles on my engine, but it has been well-maintained and runs great. I will probably do the timing belt since it is about due anyway. I'll check with previous owner regarding clutch history on the other car, as soon as I can negotiate a good price with him, and change it out if needed.
My wife thinks I am wasting my time, but before the trans crapped out, I was still getting 33-38 mpg commuting to work and running around town on errands. I told her I can't buy another car with those stats for less money than doing this swap, AFAIK.
Old May 16, 2018
Well, I wish you the best of luck with this project!
Old May 16, 2018
Colin42's Avatar
How's the body on it? I'd try to get it for less than $1k but up to $1500 would still be acceptable depending on how the rest of the car is.
You really can't, especially if you keep a bunch of parts off the old car as spares
Old May 16, 2018
piano55man's Avatar
you could always go to your local JDM importer and get an engine with 30k miles on it for 500 bucks.
Old Nov 29, 2020
Tracecross30's Avatar
Tracecross30 is an unknown quantity at this point
hey, i know this is a old threat and i was thinking of swapping my engine from my D17A2, manual engine but was thinking that it wont work because its two different transmissions and the manual wont bolt onto each other.. But i was thinking that the throttle body sensor will not work because its made for automatic transmission engine but i was assuming the connection will be the same..
also, the mount thats between the radiator and the engine on the Auto tranny is different from the manual transmission because one got two bolts and one got 3 bolts so it wont fit..
davidpaustin
Apr 29, 2015 02:23 PM
jra96
Feb 4, 2015 01:19 PM
Seby05
Engine Swaps
Jul 31, 2011 08:34 AM
sicma99ot
Buy, Sell, & Trade - Archive
Aug 17, 2008 04:22 PM
kezay
Dec 1, 2006 01:24 PM
