Transmission swap post information/Questions about automatic to Manual Transmission swaps
2003 D17A2 / BMXA Removal from top
Old Sep 8, 2022
Cardinal fan's Avatar
Cardinal fan is an unknown quantity at this point
Question 2003 D17A2 / BMXA Removal from top
2003 Civic Ex SRS 2door coupe with D17A2 and BMXA automatic.
Can the motor and tranny be pulled from the top as a single unit or is it better to separate in advance?
I’m planning on removing radiator and a/c condenser, and ABS motor in advance..
Thanks,
Dp in Wentzville, MO
Old Sep 8, 2022
Colin42's Avatar
Re: 2003 D17A2 / BMXA Removal from top
You can remove from the top as a unit. Definitely remove the rad. Should be able to leave the condenser and compressor in, just move the compressor out of the way so you don't have to evacuate the system. Might be able to maneuver the abs out of the way as well.
Old Sep 8, 2022
Thanks for response.
I’ll probably take this opportunity to replace the brake lines while motor is out; all those bends are a nightmare.
All the Best
Old Sep 8, 2022
Colin42's Avatar
Why? Are they rusted out? I'd leave them alone if nothing's wrong with them.
Old Sep 8, 2022
definitely doable out of the top, even without removing the radiator. Removing the rad def gives you lots of wiggle room though
Old Sep 8, 2022
Thanks Josh.
Old Sep 8, 2022
They have seen better days for sure. A couple were spliced as a fix from rock/gravel punctures.
pinder_83
Oct 4, 2007 05:11 PM
pinder_83
Vancouver
Sep 17, 2007 01:29 AM
reezy71
Apr 23, 2006 02:28 PM
Hwoody77
Oct 14, 2004 10:09 AM
