Do I need an alignment after rear strut replacement?
Old Nov 11, 2016
Kennykenny's Avatar
Kennykenny is an unknown quantity at this point
I have a 2005 Civic LX 4 Door, I am about to replace the rear struts. Is it necessary to have an alignment done after replacing the struts?
Old Nov 11, 2016
Re: Do I need an alignment after rear strut replacement?
As long as you remove ONLY the strut hardware and you don't pull bolts out for the LCA, UCA, or the knuckle, the alignment should not change unless ride height changes significantly.
Old Nov 12, 2016
Kennykenny's Avatar
I am planning on replacing with a quick strut. Just the 2 bolts on top and the one on the bottom. So ok?
Old Nov 12, 2016
Sounds good to me. Bolt in and go!
Old Nov 12, 2016
Kennykenny's Avatar
Thank you!
Old Nov 13, 2016
i think bottom was two bolts.
lift entire front, remove the sway bar endlink (one end should suffice) or it will resist when you try to reassemble.
Old Nov 13, 2016
For REAR struts? LOL
Old Nov 13, 2016
Kennykenny's Avatar
It is the rear. Two top, one bottom.
Old Nov 15, 2016
wops, yeah, rear dont need that :P
Old Nov 16, 2016
Kennykenny's Avatar
I'm getting ready to do the strut replacement. I am attempting to find out the torque specifications for the bottom one bolt and the two top strut bolts. Can anyone tell me what they are or a location to find out this information? Thanks!
Old Nov 16, 2016
If the strut has a pair of 10mm studs on top, my book shows 43 ft-lb for the nuts on top
if they are 8mm studs then I'd guess 20 ish
and 45 on the bottom bolt
Old Nov 16, 2016
Kennykenny's Avatar
The top has 14mm bolts.
Old Nov 16, 2016
The diameter of the studs sticking up, not the wrench size.
Old Nov 16, 2016
Kennykenny's Avatar
sorry, it is 10mm studs so 43 ft lbs. Thanks.
