Poppin/clicking noise in suspension
Old Mar 20, 2016
Handuh's Avatar
Handuh is an unknown quantity at this point
So I have a popping noise when I turn at slow speeds, or even when I turn the wheel and am not moving. the guy I bought the car from says hes positive I need needle bearings for my TEIN coilovers. however he is unsure of the size, he had ordered some before selling the car and ordered the wrong size, is there a way to tell what size I need so I don't just keep having to order a size and pray it fits.
Old Mar 22, 2016
GolNat's Avatar
Prelude Owner
Re: Poppin/clicking noise in suspension
Thrust bearing to be exact.
Contact Tein they can get you some or tell you the size.
Old Mar 22, 2016
Handuh's Avatar
Do you happen to know the best way to contact tein, I called the number in their website, (some California number) and couldn't get through to anyone.
Old Mar 22, 2016
GolNat's Avatar
Prelude Owner
That's the number I called. I think it was this one, 562-861-9161
Sending an email through the website might be another option.
Old Mar 22, 2016
Handuh's Avatar
I got ahold of them and he said he never heard of a thrust bearing before and had no idea what I was talking about. Gave him the part number for my coilovers n he looked up the manual n the only thing he could find was a thrust washer , not bearing
Old Mar 22, 2016
GolNat's Avatar
Prelude Owner
Some have bearings, I guess yours just have washers.
Try the washers. If they fix the issue then great. If not then you will need to get thrust bearings the same size as the washers.
Thrust bearing (needle bearing) with thrust washers:
Old Apr 1, 2016
SammySC's Avatar
SammySC has a spectacular aura aboutSammySC has a spectacular aura about
I had that sound in the back after installing Tein coil overs. It turns out the instructions call for cutting the rear dust covers an inch. We did that and presto! No more popping or any other noises.
Old Apr 28, 2016
XXWoodmanXX's Avatar
XXWoodmanXX is an unknown quantity at this point
Yes. I found this out the hard way, forgetting to cut the dust covers/boots as well as trimming the shaft bushings a bit.
Old Apr 28, 2016
Handuh's Avatar
Thrust bearings/washers fixed the issue!
Old Apr 28, 2016
Glad to hear it!
Sep
22
Jan 29, 2016 01:06 AM
Brittany0622
Jan 11, 2016 10:39 AM
b r i t t
Jan 3, 2016 02:59 PM
Elatria
Jan 2, 2016 08:43 PM
chris707-1
Dec 29, 2015 06:33 PM
