PLEASE READ!!! The sway bar link wont tighten!!!
Old Oct 27, 2005
joescivic02's Avatar
Abercrombie and Fitch
Alright guys........ whenever i hit bumps i hear a noise comming from the back of my car..... so i jacked it up adn what do ya know... the nut on the linkage from the sway bar i loose ( passenger side)........... its the above half... and i tried tightening it but it will not tighten whatsoever........... so how do i com upon on tightening it? i tried loosening it too but i dont think that work........ please help!
Old Oct 27, 2005
streetglower's Avatar
When you look at the flange nut that you want to tighten, in the middle of it is a joint pin, you need to hold that with a allen wrench while you tighten or loosen the other nut. I had the same problem one time untill I figured out you had to hold the joint pin while turning the nut. Look inside the nut and you will see what I am talking about.
Old Oct 27, 2005
i tried holding it with a plier......... but it slips... hows an allen wrecch going to tighten it?
Old Oct 27, 2005
it doesnt tighten it. it holds it, while you use a wrench to turn the flange nut. Look inside the flange nut and you will see what I am talking about. Stick an allen wrench in there, hold it, then use the wrench to turn the nut. Otherwise if you dont do it, the nut will always spin.
Old Oct 27, 2005
theres a los a rubber bushing.. do i need to take that out or what? please tell how i would use an allen wrech to tighten its driving me crazy... thanks
Old Oct 27, 2005
yeah but where do you put the allen wrech?i know you stick it in the middle but how would it hold it tight? its not like you can just let it stick there? sorry for being an *** i just wanna know specific.. your helping me out though
Old Oct 27, 2005
Ok, you have the nut right. Take the allen wrench and put it in the middle of the nut. And hold it. Then use the open end of a wrench and put it around the flange nut (the nut that you have the allen wrench in the middle of and turn to tighten it). There is a pin in the middle of that nut you are not being able to turn. And in order to get the nut to tighten, you need to hold that pin in the middle. Go look inside of that nut you are trying to tighten and you will see what I mean. AIM me and I will help you.
Old Oct 27, 2005
awesome i know what your saying... thanks buddy!
Old Oct 27, 2005
you arent turning the allen wrench, you are using that to hold the pin inside of the nut. you turn the flange nut with the wrench.
Old Oct 27, 2005
problem fixed!! thanks streetglower!
Old Oct 27, 2005
your welcome
Old Oct 27, 2005
manthatguysfast's Avatar
How many pots have you smoken?
manthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of light
awwww...how sweet...now this is what 7thgen is all about..you guys are bringing a tear to my eye lol
Old Oct 27, 2005
lol^^^
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
robbie374
Jul 7, 2015 02:56 AM
mrohitredd
Jun 9, 2015 06:37 AM
Rogelio Rey
May 24, 2015 08:30 PM
bsmiley
Apr 27, 2015 01:27 PM
