Brakes Post Your questions about brakes here!
ABS Issue [SOLVED]
Old Apr 7, 2021
Borran's Avatar
Borran is an unknown quantity at this point
ABS Issue [SOLVED]
Hi!
I have an ABS issue in my Honda Civic 2004. The ABS light stays on if I push the brake pedal down on start up. If I don't push the brake pedal down, the light goes off as it should.
- The ABS light never comes on if I'm driving (only on startup).
- If the ABS light stays on after startup and I restart the car, the ABS light goes off.
What could be the problem?
Top Answer
May 10, 2021
Borran's Avatar
Borran
Re: ABS Issue
A new sensor seems to have fixed the problem!
Old Apr 7, 2021
Re: ABS Issue
have someone read the codes.
ABS codes require code reader than can read them in a Honda
Old Apr 7, 2021
Colin42's Avatar
Re: ABS Issue
Checked fluid level?
Old Apr 8, 2021
Borran's Avatar
Re: ABS Issue
Yeah! I believe I have to do that.
Old Apr 8, 2021
Borran's Avatar
Re: ABS Issue
Yes I have checked! The fluid level is okay!
Old Apr 26, 2021
Borran's Avatar
Re: ABS Issue
Okay, the code reader gave a result that there is a connection problem with the right rear abs. They said that I should change the abs sensor to a new one.
Right now when I'm driving, the abs light comes on rarely but sometimes it does. I'm just wondering, can a faulty abs sensor behave like this? Or is it just a dirty sensor or something else?
Old Apr 26, 2021
Colin42's Avatar
Re: ABS Issue
If the connection is intermittent it can certainly do that
Old May 10, 2021
Borran's Avatar
Re: ABS Issue
AGregory
Jun 27, 2017 08:55 AM
azimuddin
Transmission
Oct 26, 2014 09:16 AM
blaser24nig
Oct 22, 2011 06:53 PM
brobo
Sep 17, 2011 01:55 PM
juanito
Sep 21, 2008 10:53 AM
