Brakes Post Your questions about brakes here!
Squeaking sound when pressing the brake pedal.
Old Jul 7, 2020
SlowboyZ's Avatar
SlowboyZ is an unknown quantity at this point
I recently drove came home to LA from SF. And my car recently squeaking most of the time (not all the time) when pressing down the brake pedal. I changed my front brakes for the trip. I didn't change my rear yet because they still were good. What cAn be causing this squeaking sound? I know the clicking is normal from inside. But the outside squeaks, when I'm pressing it to reverse. And coming to a slow stop. It's coming from the front.
sqeaking brake sound
Keep in mind. My car has 232k miles, I had it since 125k.
Old Jul 7, 2020
FRSam's Avatar
Click Here
Re: Squeaking sound when pressing the brake pedal.
Did you change pads and/or rotors? How well did you clean the surfaces before installing? It could be dust that built up from the old pads/rotors over time which gets squeaky when hot.
Old Jul 7, 2020
SlowboyZ's Avatar
I bought the Honda front brake kit so it was the brakes and pads. I mean these are the original rotors so would you suggest new ones? And it'll resolve the squeaking ? My car squeaks from just pressing the brake on Park. So idk how that would affect that.
Old Jul 7, 2020
SlowboyZ's Avatar
I'll definitely give them a clean with my air compressor and see if that'll work.
Old Jul 7, 2020
FRSam's Avatar
Click Here
You haven't replaced the rotors in 107k miles? Definitely replace those.
Old Jul 7, 2020
SlowboyZ's Avatar
It depends on how well you cleaned the rotors before reinstalling the pads. That may be where you squeaking is coming from. You might as well replace them though.
I actually didn't clean them that throughly. I guess you're right. It's a very cheap part to replace. I thought as long as it's not rusted it's good.
Old Jul 7, 2020
leok99's Avatar
leok99 is an unknown quantity at this point
Sound is there even car is stopped. Maybe the caliper pin?
Old Jul 7, 2020
bachands's Avatar
bachands is just really nicebachands is just really nicebachands is just really nicebachands is just really nice
^^^^^ This would be a good possibility ^^^^^^^^^^^
My car is doing this also. For me, the squeak is heard AFTER I let off the brake pedal and it's definitely from the front. I don't even have to be moving. So my guess is that either the caliper pins need lubrication or the caliper pistons are worn and causing noise. I doubt the rotors or pads are the culprit if you can hear it while the car is in Park.
You didn't mention... Do the brakes stop the car well? My brakes stop great, there's just that annoying little squeak after I let off the brake pedal each time.
troutbum24
Jan 28, 2013 03:16 AM
conspiracy90
Jun 28, 2004 09:36 AM
slamtank
Aug 27, 2003 11:46 AM
ducksause
Oct 25, 2002 01:55 AM
JoOLeESaUr
Apr 12, 2002 10:30 PM
