Brakes Post Your questions about brakes here!
Caliper Guide Pin Issue
Old Jan 15, 2020
M240B's Avatar
M240B is an unknown quantity at this point
2004 Honda Civic LX
Cleaned out caliper guide pins and lubricated with new silicon grease but, one of the guide pins won't seat back down because the air can't escape I assume. So one of the guide pins is sticking out further than the other. The guide pin in question has a rubber piece at the end of it. The guide pin that is seated to its normal length does not have this rubber piece. When I first removed the pins they were both even with each other. Will this be an issue if installed as is?
Old Jan 15, 2020
Wankenstein's Avatar
Re: Caliper Guide Pin Issue
Remove both pins and measure them..are they the same length regardless of one having a hard rubber tip and the other does not? If so, they should seat properly
Old Jan 30, 2020
nsrhonda89's Avatar
nsrhonda89 has a spectacular aura aboutnsrhonda89 has a spectacular aura about
If you are still having problems just remove the rubber piece from the slider. I removed those on both sides of my car and never had a seize slider again.
Ibrar Ahmed
Interior
Nov 15, 2019 03:55 PM
aap805
Apr 24, 2019 07:20 PM
SnoStorm
Dec 16, 2015 07:10 PM
user 92982
77
Jun 1, 2014 07:50 PM
ImportRacer2123
Oct 28, 2003 11:21 AM
