Brakes Post Your questions about brakes here!
Brakes Squeaking
Old Jan 30, 2006
hardcorean's Avatar
hardcorean is an unknown quantity at this point
Brakes Squeaking
Yeah i have a 2001 lx sedan, the first 5 minutes the breaks squeak at low speeds, but after awhile the squeaking stops. And in order to come to a full stop i have to be pushing like more than half way, is that normal?
Old Jan 30, 2006
tfnaaf's Avatar
BLDNPSI Mod
Brake squeek is normal, but i suggest that you have them checked to make sure they havent worn down to far.
Old Jan 30, 2006
dragman99's Avatar
dragman99 is an unknown quantity at this point
if the rear brakes are drum brakes, they'll probably atleast need adjusting. if it's disc all the way around the car, more than likely something is worn out if there is that much travel in the pedal. give them a good cleaning as well if nothing is worn out.
Old Jan 31, 2006
hardcorean's Avatar
And if i wanted to replace the rear drums with discs is that possible? Will it mess up anything? Do you recommend it?
Old Feb 1, 2006
tfnaaf's Avatar
BLDNPSI Mod
a simple search will give you the info you need on the rear disc conversion i have it and like it..
Old Feb 1, 2006
DDragon7's Avatar
IBTL
Old Feb 3, 2006
spoonJDMlX's Avatar
spoonJDMlX is an unknown quantity at this point
are they new? its normal to have brakes squeak when the rotars are cold..
Old Feb 3, 2006
o6er's Avatar
o6er is an unknown quantity at this point
i have the same problem with my new 06 civic.
i do have rear drum.
Old Feb 4, 2006
04civic07's Avatar
Living Life Turn After Turn
04civic07 will become famous soon enough04civic07 will become famous soon enough
if you havent changed your pad in a long time it's probably your brake pads out. the squeaking will progress with in 2 weeks. if you wanna check , lift your car, take the wheel off of one of the front corners and just look on the side of the caliper, there should be a small peep hole. there will be a thinner metal layer and then the pad itself.
for rear disks, you gotta get them off an 02-03 EP3 (si model) cant use 04-05 because they're 5 lug pattern. but honestly just get new brake shoes if any. the disks are great, but $$$ if you're only going down the street and back. unless you autocross/track :P
Mad Dog Tannen
Sep 12, 2015 12:48 AM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
thaler4cuse
Sep 7, 2015 08:25 PM
Josh 1973
Sep 7, 2015 10:10 AM
rainman15
Sep 6, 2015 11:10 AM
