Idle Issues If you have idle issues, post here!
2002 civic rough idle [solved]
Old Nov 22, 2022
Frssrf16's Avatar
Frssrf16 is an unknown quantity at this point
Hello! New to the forum. I’ve been reading all the posts on idle issues and can’t seem to figure out mine. 2002 Honda Civic Ex auto transmission. I got a check engine light for po303 cylinder 3 misfire. I replace all the spark plugs with NGK spark plugs and verified they were gapped correctly. Issue still persisted, so I started to pull ignition coils while the car was running. All coils cause rpm change when unplugged expect cylinder 3. So I replaced the ignition coils with OEM.
after changing spark plugs and coils, I don’t get a CEL but still feel a misfire, especially at idle and while stopped at lights. So I cleaned the Egr valve and intake manifold passageways as well as install a new intake manifold gasket. The car still feels like it’s missing at stops, idles around 500 and the car shakes.
also I don’t believe the head gasket is blown as the car never overheats, and I’m not losing any coolant, or seeing smoke from tailpipe.
any ideas and tips would be greatly appreciated!
Old Nov 22, 2022
BrotatoChip's Avatar
Super Moderator
re: 2002 civic rough idle [solved]
According to the service manual idle should be 720 +/- 50 RPM at warm idle with no electrical load. 500 is a bit low and could cause some vibration.
Old Nov 22, 2022
Frssrf16's Avatar
Update!
i cleaned all the injectors today and the car seems to be running a lot better! If anything changes I’ll update.
Katie0917
Jul 28, 2022 09:36 PM
RHewitt
57
Feb 16, 2021 05:06 PM
benparker717
18
Aug 3, 2012 09:19 PM
free_refil
Mar 23, 2010 08:46 PM
boostnm3
Buy, Sell, & Trade - Archive
Dec 22, 2009 10:57 PM
