Idle Issues If you have idle issues, post here!
Idle issue
Old Jul 6, 2021
J1664's Avatar
J1664 is an unknown quantity at this point
Question Idle issue
Hello,
I've a Civic EP2 2004 hatchback 1.6 L manual transmission with 300k km. It starts great but after 1min the idle goes down to 500rpm, sometimes it stalls, then it goes up to 1800rpm. It repeats this until the engine is at operating temp. It stared that problem in winter and now is doing every day on cold engine - check engine on.
In neutral, the rpm goes up following my throttle but once released, it remains for a while at 1300 rpm, before going to normal 800rpm. Driving downhill in neutral, the rpm stays at 1500-1700 I have do to a full stop to have it at 800 rpm. I've cleaned the IACV and TB but I didn't replaced the IACV gasket since I'm not sure of the problem. Besides this, the car works fine once the engine is at operating temperature.
Many thanks in advance!
Here's the link:
Old Jul 6, 2021
BrotatoChip's Avatar
Super Moderator
Re: Idle issue
I know you said you cleaned the IACV but the fluctuating idle sounds like a bad/sticking IACV.
Old Jul 9, 2021
Wankenstein's Avatar
Re: Idle issue
If it's not a sticking IACV as BC suggested then it might be a vacuum leak that seals when the engine gets to operating temp. Seal the throttle body and do a smoke test on it via the brake booster or other large vacuum line. There's info online how to make a homemade smoke tester or you can use a cigar and tubing as shown by Scotty Kilmer:
lsdaddy0
15
Jul 6, 2017 11:17 AM
gulzarh
General 7th Gen
May 11, 2017 07:16 AM
agb22
Dec 3, 2016 01:03 PM
thana
Jun 15, 2015 11:58 PM
pichon
Mar 27, 2002 12:04 AM
