Bleeding clutch
Old May 18, 2003
silverrazor's Avatar
silverrazor is an unknown quantity at this point
Unhappy Bleeding clutch
Howdy! I have a 2001 EX Coupe with 65K miles. Just wondering if anyone out there has bleed their clutch yet. I've done brakes a million time, but the damn clutch is not cooperating. I'm pretty sure that all of the air bubbles are out of the line, but when I close the bleed nipple at the slave cylinder and start pumping the clutch pedal...it stays limp!
Are there any issues I need to worry about? Any tricks to beat this S.O.B?
PLEASE let me know.
Thanks!
-Silver
Old May 19, 2003
solar's Avatar
solar is an unknown quantity at this point
Why are you bleeding the clutch Slave anyway? Did you replace the Master Cylinder or Slave Cylinder or both? As far as bleeding goes its really simple, have someone sit in the car, make sure the Clutch Master Cylinder is full of fluid. Open the bleeder valve on the Slave and have your friend SLOWLY push the clutch pedal down to the floor. Once the pedal is on the floor,keep it on the floor until you close the bleeder and let the cltuch pedal back up, repeat until all the air is out of the line. Make sure the Master stays full, it shouldn't take but a couple of times before its done.
Is the car shifting okay or is there still a problem? Its possible that even though you bled the line clear of air the Master Cylinder could be bad or the Slave or both. They can have internal problems allowing the fluid to pass over the seals.
BTW just a FYI that most people don't know. The clutch has a seperate Master Cylinder from the Brake Master Cylinder, they both work the same way and are called the same thing, its just a differnt funtion of the car.
Old Sep 17, 2010
daza2506's Avatar
daza2506 is an unknown quantity at this point
Re: Bleeding clutch
After fitting new clutch to honda civic 1.7 d had problems with slave cylinder and then master cylinder both of which had to be replaced...
Old Aug 29, 2021
Ninjaturkey's Avatar
Ninjaturkey is a jewel in the roughNinjaturkey is a jewel in the roughNinjaturkey is a jewel in the rough
Re: Bleeding clutch
PLEASE let me know.
Thanks!
-Silver
I tried hand pumping and another person pumping the pedal without success. I wound up using a Power Bleeder with the euro attachment. One person held it on to the reservoir to keep the pressure even, the other pumped it to 12 psi and opened the bleeder.
​​​​​​​Since I use old threads regularly to figure out how to fix things, hopefully this thread necro is forgivable and useful.
devinkkperry
Transmission
Oct 28, 2020 03:55 PM
bsmiley
Jun 14, 2014 10:46 PM
EM2 RYDER
Nov 18, 2008 09:26 PM
SleakCivic02
Aug 19, 2005 01:39 PM
slowwhitecivic
Aug 13, 2005 09:05 PM
