2004 Honda Civic auto transmission slipping
Old May 28, 2024
cyrusyn's Avatar
cyrusyn is an unknown quantity at this point
Hi Everyone, I got a 2004 Honda Civic with auto transmission and 200k miles (motor has 40k miles) for free from a relative. One issue this car has is the auto transmission slips when taking off as you can see in this video:
As you see I have to rev the motor to 2000 rpm in order to launch from stand still. Transmission fluid level was low so I filled it up with Lucas Transmission Fix and things got a little bit better but slipping is still there along with flashing green light at D range in instrument cluster.
I scanned OBD codes and got P2770: torque converter clutch circuit high. Searching about 2770 on the internet points to replacing torque converter clutch solenoid switch. I would like to ask you if you have had this issue before. Judging from the youtube video, will changing both solenoid switch A and B fix or improve this slipping or do you think I need a new transmission? Thank you for your opinion!
Old May 29, 2024
Colin42's Avatar
Re: 2004 Honda Civic auto transmission slipping
Try changing the fluid. Do a drain and fill 3 times, with 20 mins of driving in between. See if it gets better
Old May 29, 2024
BrotatoChip's Avatar
Super Moderator
Torque convertor lock isn't used until you're going ~50 mph. It wouldn't cause a slipping transmission.
Old May 29, 2024
cyrusyn's Avatar
So do you think I should ignore P2770 code?
What do you think is causing me to press gas pedal a lot more than normal in order to launch the car from stand still?
Old May 29, 2024
try fluid first, easier and historically helps the trans on these cars. no guess, test
Old May 29, 2024
cyrusyn's Avatar
Thank you very much for suggestions. Which brand ATF do you recommend? Will any Japanese import ATF work for high mileage transmission like mine? Should I continue to add Lucas Transmission Fix?
Old May 29, 2024
honda fluid. hondas are pick
my manual trans uses engine oil weight... nobody else does that...
Old May 30, 2024
Colin42's Avatar
Vavoline and Total make fluids that are honda compatible, make sure you get the correct one. Stop using the Lucas
Old May 30, 2024
Colin42's Avatar
Because the trans is slipping...
Stickboy318
Apr 7, 2015 10:07 PM
ATMJDM01
18
Apr 16, 2014 08:51 PM
amysylvester
Aug 29, 2011 09:12 PM
V16Civic
Aug 14, 2006 07:04 PM
trev0006
Jan 14, 2004 06:20 PM
