Won't shift into fifth gear
Old Jul 19, 2020
Crowley01's Avatar
Dazed and Confused
Crowley01 is an unknown quantity at this point
So, I did a complete transmission swap. Installed a EFT stage 2 shift kit w/ flywheel.
Now, I have to push the clutch ask the way to the floor to shift gears, and I cannot shift into 5th gear.. Do I have to adjust the linkage or what.. I'm not trying to take it to a repair shop. And before you ask, yes I put all the fluids in it.
Any help would be greatly appreciated.
Old Jul 19, 2020
Re: Won't shift into fifth gear
Did you unbolt the slave cylinder from the trans without disturbing the tube (hydraulic line) , or did you disconnect the tube?
ocnwolf99
Jun 5, 2018 01:46 PM
jdmb16b
Dec 10, 2011 11:05 AM
phantom-civic
Aug 21, 2006 09:24 PM
KDawg88
Feb 4, 2005 08:15 PM
J-spec-SiR2
Apr 7, 2004 11:51 PM
