Transmission won’t separate
Old Jul 29, 2018
2002CivicTDA's Avatar
2002CivicTDA is an unknown quantity at this point
Hello,
I have a 2002 civic manual transmission.
To my knowledge, I removed all bolts connecting it to the engine and it still will not disconnect .
Any suggestions?
Old Jul 29, 2018
Slumpertcivic's Avatar
Re: Transmission won’t separate
You must have missed a bolt or two.
Once all the mounts, starter, bottom brace , and like 8 big bolts are off, it will only be held on by two guide pins and possibly a rusted on clutch.
Old Jul 29, 2018
mac25's Avatar
Dr Krieger of Modification
Not sure if you saw them but there are two kind of hidden bolts under the thermostat housing block (...or whatever that thing is called).
Perhaps there is dirt/corrosion holding it together? You could try hitting it with liquid wrench and then tapping around the case with a rubber mallet.
Old Jul 29, 2018
Thank you both.
I’ll double check the bolts located under the thermostat housing. I’m sure it’s in neutral... if for any reason it’s not, would that matter?
Old Jul 29, 2018
Gear selection has nothing to do with connecting to engine
Old Jul 29, 2018
The dowel pins can get corroded and seize in their holes, necessitating the use of force (wedge, two prybars) to separate the trans from the engine
Old Jul 29, 2018
There was a bolt I missed and the son-of- gun pope right off.
Thanks fellas!!!
Old Jul 30, 2018
I rotated and changed only the clutch release bearing and reinstalled the transmission.
Now the transmission won't pull. Any recommendations before I drop it again.
To the best of my knowledge the release bearing was installed correctly.
I did not break the slave cylinder line and it does actuate.
****Everything was working prior*** Just had a defective release bearing.
Old Jul 30, 2018
Axle not fully seated in trans?
You boogered an inner cv joint by trying to pull on the axle shaft instead of prying the cup out of the trans?
Old Jul 31, 2018
It was the drivers side cv axle. I had the hardest time popping that back in.
Thanks ezone
Old Jul 31, 2018
Thanks ezone
Old Sep 18, 2019
Cory Nida's Avatar
Cory Nida is an unknown quantity at this point
I’m replacing the case gasket and I cannot get but about 3/4” gap between the two cases. Is there a truck to lining up intervals so the case will slide off? Thank you in advance for the help. I really appreciate it
Old Sep 18, 2019
Did you remove the detent ***** and the circlip ring ?
Old Sep 18, 2019
Cory Nida's Avatar
Well I did remove the snap ring but I was not aware the ***** came out also.
Old Sep 18, 2019
Did you remove the shift fork?
Old Sep 21, 2019
Better get a real service manual!
Old Sep 21, 2019
mac25's Avatar
Try youtube, I searched "2002 manual civic teardown" when I rebuilt my transmission.
There might be a video for your transmission.
uitenhage
Aug 12, 2018 11:01 AM
sekhonjatt
Feb 27, 2013 10:25 PM
teampointless
Texas
Sep 13, 2004 09:49 AM
