Transmission Problems!
Old Jun 9, 2018
BlackBorrego33's Avatar
BlackBorrego33 is an unknown quantity at this point
I have a 2004 honda civic 1.7L sohc that doesn't go into gear. When you turn it on it will pick up the gear you select just fine but after about 30 seconds to a minute it Will just slip . revs will go as if the transmission wqs in neutral. Its seems like somethingnis deactivating after the first couple of seconds of operation. We took out the transmissiin and swapped the torque converter. No luck with that and also changed the torque converter clutch solenoid. Just stumped. Please help!!!
Old Jun 9, 2018
Wankenstein's Avatar
Re: Transmission Problems!
There's an internal filter ...if it gets clogged with debris it can cause shifting issue. Other than that could be valve bodies or clutch packs. Did you test and clean the shift solenoids and gasket screen?
Old Jun 9, 2018
Yes we cleaned the solenoids and the screens and verified their operation. Is the filter internal requiring a transmission dissasemble? Or is it on the lower cover maybe?
Old Jun 9, 2018
Yes.
And it usually means it's time for a rebuild, because whatever caused enough debris to clog the filter needs to be addressed.
theteju
Oct 21, 2017 11:05 PM
doggedpursuit
Transmission
Mar 23, 2017 10:07 PM
wrencher
Transmission
22
Dec 29, 2015 08:19 AM
Whitexj
Sep 30, 2015 02:04 AM
honda200192
Apr 12, 2015 10:28 AM
