Clutch Needs Replacement?
Old Oct 5, 2011
em2maxamillian's Avatar
em2maxamillian is an unknown quantity at this point
Got a 2004 EX with the 5 speed MT, 54k miles on it. The clutch is acting strange. I swear the bite point is moving higher up on the pedal. But what's really annoying is that the bite point is very sudden. I mean, that sucker bites all at once, especially in the morning when I first start driving. I've always had the fluid flushed regularly and it's not leaking clutch fluid. Suggestions/thoughts? The car is second hand, but the previous driver seemed to know how to drive stick. Thanks guys!
Old Oct 5, 2011
anibis's Avatar
anibis will become famous soon enoughanibis will become famous soon enough
Re: Clutch Needs Replacement?
With only 54k on it I doubt your clutch is even close to needing replaced, I have 120k on my '05 Civic and the clutch doesn't bite like it used to but it's still going strong. I've heard of people getting over 200k on a stock clutch.
Clutches are always more abrupt when they're cold, that's to be expected.
More than likely your clutch pedal just needs adjusted.
Either take it to a shop or follow this DIY:
https://www.civicforums.com/forums/1...djustment.html
Old Oct 5, 2011
GolNat's Avatar
Prelude Owner
If your bite point moves it could be the clutch slave cylinder. I needed to replace mine but the car has 140k on it. My clutch bite point moved down though not up and it wasn't loosing fluid cause there was a leak internally. Since you don't have many miles on it would try what anibis said.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
pantdino
15
May 13, 2015 02:22 PM
crowtoo
May 11, 2015 06:50 PM
bsmiley
Apr 27, 2015 01:27 PM
thesushiboy
Apr 12, 2015 02:54 AM
