Mounts going or the trans?
Old Sep 28, 2011
em2maxamillian's Avatar
em2maxamillian is an unknown quantity at this point
I posted before, but no one commented. I got a 04 EX with 54k miles, 5 speed MT. When i put it into reverse, and let the clutch out, sometimes there's a rattling noise from under the hood. It doesn't happen if I rev the engine and "ride" the clutch, but if I try to balance it out, it comes up, especially if I bog the engine a bit. Could this be a mount or the trans itself? I just changed the fluid in the trans, but it has the original clutch.
Also, the bite point on the clutch is pretty sudden. I'd say less than an inch. Is this normal? It's so hard to get it off the line smoothly. Should I have the trans inspected during my next service? Can you adjust the bite position? It's kinda high, and I know this is a hydraulic clutch, so ya, just wondering.
Sorry, I'm more used to older cars, so this one is a bit of a mystery to me. I appreciate any help. Thanks!
Old Sep 28, 2011
Re: Mounts going or the trans?
all i can help with is the mount. you can see if its torn and sometimes feel around for the rubber part inside. civics have all sorts of problems with these and usually the shared engine/trans mount is the first to go. i was surprised how much it affected shift quality on my auto when one leg of the shared mount broke. and this was not even the dedicated trans mount, which was fine. trans mount is somewhere on the passenger side sortof near the battery under the stock intake. front shared mount is down at the bottom in the middle of the radiator.
Old Sep 29, 2011
thanks for the help. Ya, I'll have them check the mounts next time I go in. Anyone know what I can expect in the way of costs? I would just do it myself, but I moved to the city, so I have no where to do it. The obvious choice would be to go to the dealer, but I know they're gonna cost me an arm and a leg.
Old Sep 29, 2011
couldnt be more than an hour of labor. took me an hour in the garage and i didnt know what i was doing lol, first time changing it. might be more labor if its the rear mount tho. front one is cake.
mgrantaz
General
May 2, 2022 05:40 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
twd000
Oct 4, 2015 12:52 PM
jackoncruzpr
Sep 29, 2015 07:59 PM
FistRock
Sep 4, 2015 08:00 PM
