tranny noises
Old Jun 13, 2006
civ_nate's Avatar
civ_nate is an unknown quantity at this point
tranny noises
okay, so here my story, i was expierencing some noises from my tranny, low rpms in 1/2/3 gear [5 speed] and i came on here and seen about the input shaft bearing and throw out bearing problems.
so i went into local honda dealership as i was told honda would not cover under warrenty. so i went in with several compaints, thought my cat was clogged, as i have lost about 50% power after about 50k km, the tranny problem and my gas guage doe snot work.
anyways, they took the carfor a drive and told me that the tranny was extremely f*cked, all bearing need to be replaced as they were crushed!!!, as for the cat, they said no problems with the power....dumbasses...and the guages if i take off the faces, they will try to replace them for me under warrenty.....
so today i get a call form the, my app was 2morrow at 730am, and they need to reschedule me as they had sum1 else whose tranny litterally fell appart and they only have one person who can work on trannys and mine si not that important as it isnt too bad....
i flipped at buddy ont he phone cuz now i ahve to wait 2 weeks b4 i can get mine fixed....
whatshould i do... what would u do>?
Old Jun 13, 2006
zen_master's Avatar
wow man. got the same bearing problem too with the tranny.......
i'm not gonna fix it on the dealer though.....gonna let my local store fix it...lol
Old Jun 13, 2006
civ_nate's Avatar
dude try and see if it is under warrenty
Old Jun 13, 2006
why are you having the dealer fix something thats not even warrantied? go find a better place that can fix in a few days and do better job.
Old Jun 14, 2006
zen_master's Avatar
.the input shaft bearing is not covered under warranty.
synchro, tranny slipping = yes.
i agree with gearbox. maybe you should find a good performance shop around ur local area?
Old Oct 2, 2006
civ_nate's Avatar
so here the result, i waited, went in, they covered the bearing, in fact they replace ALL the tranny bearings. also they covered the guages. in regards to the power loss they said they will not fix cat cuz they dont think that si what it is. so i tried changing the spark plug which fixed soem of it but i still do not know
Old Oct 2, 2006
russo-r34's Avatar
russo-r34 is an unknown quantity at this point
try adjusting your throttle cable, and are u running stock???
May 4, 2016 07:14 AM
Kcpowerhouse
Aug 25, 2015 01:15 PM
WaryDriver
Aug 22, 2015 06:50 PM
15EXCoupe
Jul 30, 2015 12:59 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
