Maint. Required Light?
OK is it like normal for the Maint. Required light to flash and beep upon startup of the car? It just started doing it yesterday
HELP ASAP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
and as miss cleo would say.....
you just turned up 8000 miles, did you mon? i can see it well now!
and if you want to do well wit dee ladeez, den ditch all dose exclamation points!
What freak was trying to say is you hit your 10K mile checkup point, which is an oil change, if you do it regularily then you need not worry, if you call your dealer, or any honda dealer for that part, they will let you know how to turn it off, really easy, you dont have to worry until you hit like 30K miles....
Civicforums Junkie
[IMG]i/expressions/face-icon-small-mad.gif[/IMG] OMFG [IMG]i/expressions/face-icon-small-mad.gif[/IMG]
USE THE SEARCH!!
THIS HAS BEEN COVERED NUMEROUS TIMES
OK...I'll help you out like I do everyone else:
HOLD IN THE 'TRIP' BUTTON
TURN THE KEY TO THE #2 POSITION
WAIT UNTIL THE DASH LIGHTS GO OFF
TURN KEY BACK TO #0 POSITION
RELEASE 'TRIP' BUTTON
*ODOMETER MILEAGE NEEDS TO BE SHOWING WHEN YOU DO THIS*
NOW START THE ENGINE...NO MORE LIGHT
[IMG]i/expressions/demon.gif[/IMG]
USE THE SEARCH!!
turn your key half way until all the lights on the dash come on then push in the od resest thingy and hold it!!!!! now start your car and it should be gone!! it happened to me after i got the car serviced they forgot to reset it so i called and they told me how!
Civicforums Junkie
Quote
[hr]Originally posted by: Wantobedoneup
turn your key half way until all the lights on the dash come on then push in the od resest thingy and hold it!!!!! now start your car and it should be gone!! it happened to me after i got the car serviced they forgot to reset it so i called and they told me how![hr]
did you not read the other replies??
already explained it
97-DX-Lover
Jun 14, 2015 06:07 PM
Hoagey
Lighting
Jun 13, 2015 01:07 PM
