Electronics Post your electronic questions here!
Replacing 2005 EX auto Speedometer, mileage carryover?
Old Nov 11, 2023
superchess's Avatar
superchess is an unknown quantity at this point
My speedometer needle started glitching out and is now stuck at 120+mph regardless of ignition position. I was wondering if I replace the gauge, will the original mileage of the car carry over to the new gauges odometer display, or will there need to be some type of adjustments made by a dealership? I want to make sure that everything stays legit before I replace it myself.
Thanks for your time.
Old Nov 11, 2023
FRSam's Avatar
Click Here
Re: Replacing 2005 EX auto Speedometer, mileage carryover?
No. Whatever gauge you swap in will contain the mileage of the car you swapped it from. Not sure what the implications are you get that remedied, or whether that’s actually legal.
Old Nov 11, 2023
depends on state?
you will need to have a document showing the mileage at which the cluster have been replaced and what is showing. (this is to prevent fraud, like putting a cluster showing a much lower mileage for the actual car).
Some companies can maybe roll the mileage if it is lower than the car? (I think they spin the cluster until it gets there)
moved out of the DIY since it is not a DIY article
Old Nov 13, 2023
thetut's Avatar
thetut is a glorious beacon of lightthetut is a glorious beacon of lightthetut is a glorious beacon of lightthetut is a glorious beacon of lightthetut is a glorious beacon of lightthetut is a glorious beacon of light
Contact United Radio. They specialise in automotive electronics repair and programming. There may be others closer to you.
Old Nov 21, 2023
superchess's Avatar
Looks like I'm going to need to find a shop which can try and run up the mileage on a used odometer so that it matches my cars?
Old Nov 21, 2023
FRSam's Avatar
Click Here
Are you in a state where it's required? I'm not sure I'd even bother - just take a picture before you swap and then take the picture after. That documentation alone should be acceptable should you sell it in the future.
Old Nov 22, 2023
BrotatoChip's Avatar
Super Moderator
With a little bit of technical know how, you can run up the mileage on a cluster by yourself using a microcontroller. But, you can only add to the odometer, not subtract. Cluster will only read up to ~140 MPH which will take a long time. Adding 10k miles to the cluster will take 70+ hours.
Old Dec 15, 2023
superchess's Avatar
UPDATE: I changed the cluster and it did not update the mileage. I got the mileage of whatever the original car the other cluster came from was. I was also dumb and didn't remove the battery when doing this change so the SRS light went off (reset cleared it). But PSA: disconnect battery for all electrical modifications!!
Old Dec 15, 2023
Super Moderator
Yes, because the mileage is stored in the cluster. That's what we were telling you.
Old Dec 15, 2023
superchess's Avatar
Yup, thats what I expected as well, just wanted to provide an update
laithmajed91
Feb 9, 2012 05:53 PM
CdnSilverStreak
Alberta
Mar 11, 2005 06:33 PM
HomerSimpson
Chicago
Feb 18, 2005 01:53 PM
ffokuf
Mid Atlantic
Dec 29, 2004 10:45 AM
SlvrLx26
South Cali
Nov 12, 2004 01:24 PM
