Electronics Post your electronic questions here!
Parking Brake Light After Cluster Swap
Old May 20, 2020
FF91's Avatar
FF91 is an unknown quantity at this point
Hey guys i have a 2004 civic coupe dx special edition 5MT i installed cruise from a 2004 lx sedan i took the wiring harness from the lx. It had abs and i cut the connectors off and sealed them off everything works except the abs light was on till i grounded the abs wire the problem im having is the park brake light stays on....whats the deal???
Old May 21, 2020
BrotatoChip's Avatar
Super Moderator
Re: Parking Brake Light After Cluster Swap
I'm assuming you meant you swapped clusters and not the cruise control module. The parking brake light is commanded on/off by the multiplexer over a communication line (white/green wire). Does the light telling you a door is open work?
Old May 21, 2020
FF91's Avatar
I installed cruise stole the wiring harness off a lx as well as took the cluster from the lx i have no trunk/door open lights on this cluater that work as well as the high beam indicator is on untill i turn my dtrl's on do i need to repin my cluster connections even though i took the wiring harness from the same car as i took the cluster from
johnny18
Electronics
May 17, 2020 04:21 PM
aabonline
Oct 16, 2011 03:19 PM
juanito
Sep 21, 2008 10:53 AM
MotorWeb EM2
Brakes
Dec 27, 2006 03:42 AM
Silver_JS5
Lighting
Feb 24, 2005 12:51 AM
