02 civic Ex sedan Instrument Srs HELP PLZ
I have a 02 civic manual ex sedan that has a bad speedometer. My car has side airbags but it is impossible to find a cluster from a car with side airbags. Can i change the cluster to one from a car without side airbags or does it have to be from one with side airbags? HELP
Re: 02 civic Ex sedan Instrument Srs HELP PLZ
Are you sure it's the cluster that's the problem? Usually it's a cable going to the cluster that's corroded or jolted loose.
I'd be pretty surprised if the cluster was the issue.
To answer your question, I'm pretty sure any normal cluster would work, but in order for the side airbags to work, you'd need it from a car that came with them.
Best bet would be to find a service manual. The Haynes one is excellent, and you should have no issues finding one at your autoparts store.
At least in North America.
The SRS indicator light in the cluster is just an LED. I would think the system would still work normally without it you just wouldn't know when they system had an issue.
gorank
General 7th Gen
Oct 9, 2018 01:48 PM
Apollyon02ex
Jan 28, 2012 06:22 PM
stock03
Dec 29, 2009 07:12 PM
