Scorching summer heat: how many of you still use 5w20?
I know our manuals say to use 5w20 year-round, but with the summer heat and a bunch of long road trips coming up, I'm tempted to go to at least 5w30 for my next oil change.
Any of you change to a higher oil weight for the summer for your 7th gens?
I use 5W20 from Royal Purple. And I recommend it to all my friends.
Quote
[hr]Originally posted by: Ronin
Any of you change to a higher oil weight for the summer for your 7th gens?[hr]
[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
I thought the "w" stood for winter, for cold weather startup?
I found this bit of info:
So I think there is a bit of difference in hot weather between 5w20 and 5w30, since the "20" oil will thin out more than the "30" in hot temperatures.
(But of course, no difference during the winter.)
Quote
[hr]Oil viscosity is affected by temperature. A heavy oil that stays relatively thick at high temperatures would have a high-viscosity rating of 30, 40, or 50. A thin oil that flows freely at low temperatures would have a lower number. Because temperature affects how well any liquid flows, motor oil viscosity is rated at both high and low temperatures. The lower viscosity numbers of 20, 15, 10, and 5 are accompanied by a "W" for "winter." Some motor oils today have a single viscosity rating, such as SAE 30, but many are designed to work in a wide range of temperatures. Such oils have a dual viscosity rating, such as 5W-20 or 15W-30 ...... Another way of looking at multi-vis oils is to think of a 5W-30 as a 5 weight oil that will not thin more than a 30 weight would in hot weather. [hr]
Quote
(But of course, no difference during the winter.)[hr]
Quote
Ronin you are correct about the "w" , it does mean winter, and some people say "weather". Its really the same thing.
A straight oil, like a SAE 30, is great for summer climates because its "thinner" than a "10w" type oil. In the winter you want a oil that won't be a problem with very low tempuratures, thats why most northern cars run with a 10w or 15w type oil. In a warm climates the oil is quicker to "seperate" and lube the engine, the "thinning" of the oil is really just a mith, you really do want the oil to "thin out" because most oils in engines that are maintained regularly will have all the vitale engine parts protected quicker than a higher "w" type oil in warmer climates.
I was wondering the same thing. I just got a 2002 Civic ex. I figured the 5w-20 would be to thin. So you all agree it's ok to run that then? How many miles has anyone put on there motor with this oil?
Quote
2Hottie
well. i have about 20K miles on my 2002 Civic EX. Even though they say you only have to change the oil every 5,000 miles, i do it every 3,000. But I have been using 5w-20 since I got the car and it is running with no problems. *^_^
Quote
[hr]Originally posted by: CivicDegredation
well. i have about 20K miles on my 2002 Civic EX. Even though they say you only have to change the oil every 5,000 miles, i do it every 3,000. But I have been using 5w-20 since I got the car and it is running with no problems. *^_^[hr]
10W 30 would definately be better for you car considering the temp, but to get the new "purple" oil doesn't cost that much more over time. 5 w 20 gets very runny in hot temp, but still works. just the facts i use 10 w 30 right now as its 90+ in ohio and 100% humidity
Quote
[hr]Originally posted by: 2k1SINCE00
10W 30 would definately be better for you car considering the temp, but to get the new "purple" oil doesn't cost that much more over time. 5 w 20 gets very runny in hot temp, but still works. just the facts i use 10 w 30 right now as its 90+ in ohio and 100% humidity[hr]
What difference would outside temperature and humidity make to your engine oil when your car reaches normal operating temperatures? I mean, a normal car engine would be running at a steady temperature regardless of the outside temperature, whether it was winter or summer, right? And that normal engine operating temperature would be way higher than the outside ambient temperature.
So in summary: how does outside temperature affect engine oil that's inside an engine which is operating at a much higher constant temperature? I mean, wouldn't a light oil like 5w20 provide the same protection during winter and summer, if the internal engine temperature is always the same regardless of season?
You got to remember guys, if you switch to the 5-30 your going to lose some gas mileage....Maybe 1-2 mpg.....I just run Amsoil 5-20 and cars been taking the summer heat so far....Its a lot quieter at idle and I've noticed a gas mileage increase......[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
I think the engineers at Honda know what they're doing, so if they say 5w-20 all year around, thats what I'm going to do. I think Hondas track record speaks for itself.
Quote
[hr]Originally posted by: solar
[hr]
Do not, I repeat, do not use the 5w20 that Honda recommends. Instead use 5w30 or 10w30. I use 5 in the winter and 10 in the summer. Xw20 does not provide enough protection to engine parts because the viscosity never reaches the thickness needed for LONG LASTING protection. You get better mileage because of the reduced viscosity. However, your car will run warmer and you might risk pre-ignition or detonation if you drive under extreeme conditions. The higher the second number is the more protection you get at higher engine temps. The Xw20 is fine if you don't ever rev your car past 3000 RPMs and stuff. That's how it's tested in the factory.
Yes, that's what the manual says, I know, but read how they test their cars. Do you rev above 3000 RPM? Well, during their oil and fuel efficiency tests THEY DON'T! Use your 5w20 and change it every 10k miles if you want to. I'll continue to follow my advice and when it comes time to rebuild the engine, as you surely will if you keep the car over 150K miles, I'll still be driving mine with the original engine.
Those of us who have studied engine internals know the danger posed by FOD in the oil. FOD stands for Foreign Objecd Debris/Damage, depending on who you ask. The particles that are deposited in your oil actually thicken it. If you start with a 20 SAE top weight and you run for, say, 10k miles, you might have a 40-50 top weight oil equivalent by the time you change your oil. This is not good for a car. You should never run your car with to high or too low a viscosity. If you maintain your oil viscosity as constant as possible you are helping your engine last alot longer. Those same particles that get incorporated in your oil reduce the thermal efficiency of your oil, i.e. it won't carry heat away from the metal as efficiently as it should, plus the added particles cause friction, creating more heat that can lead to pre-ignition and detonation. Those are all bad for your engine, if you haven't figured it out yet.
That's why I put 3k miles as a recommended oil change interval. That is what I live by. My 86 Mazda 323 lived to the ripe old age of 193,391 miles before the engine needed to be rebuilt for the first and only time. The only reason that happened is because my father bottomed out the oil pan and the engine oil light never came on. We found out it had no oil when the car overheated and started knocking. Two weeks after we rebuilt the engine the car was stolen and when recovered it was useless.
For those of you who change your own oil and say you drive over 3k do me a favor: Next time you change your oil at your regular interval compare the oil that you are changing with the oil you are putting in. Put them both in a plastic cup or a glass or something you can see through. Notice anyting? Yeah, that old oil is nasty dirty. Do you really want that in your car? I don't!
Now, as for Ronin's question. Your coolant is run through an air to water heat exchanger (radiator) The hotter the outside air temp (OAT) the less it will cool the coolant running through those lines. That's why your engine does run at higher temps in higher OAT situations. Its reversed when talking about cold OATs. If you ever drove in really cold temps, like up in Washington in the winter, you might notice it. My RX-7 would never warm up because it was so cold outside.
EDIT: Spelling
Quote
[hr]Originally posted by: 1955
to all of u misinformed guys out there...the W is stand for weight[hr]
I think YOU'RE misinformed[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG] The "W" means that the oil maintains its viscosity at 0°F, there for is suitable for Winter use, it has nothing to do with weight.
Quote
Quote
[hr]The W means the oil meets specifications for viscosity at 0 F and is therefore suitable for Winter use. [hr]
Quote
My car is made in japan and the manual gives the following choice of engine oil to use:
For ambient temp range of -20 to 100 F:
0w20, 0W30, 0w40, 5w30, 5w40
For ambient temp range of 0 to 100 F:
10w30, 10w40
For ambient temp range of 10 to 100 F:
15w40
The strange thing out of this is that there is no 5w20 specified in my manual nor on my oil filler cap!!!
Good post silverdevil. It's good to learn somethin new. When I change my oil (which won't be any time soon) I think I'll go with the 30 oil. I run my car hard sometimes, but more frequent at night.
Don't want the engine blowing up in my face. The weather is pretty warm here and I do change my oil every 3k miles... had nothing but 5w-20 in the engine and now I'm at 21,200 miles just about. 5w-20 always looked so thin... bleh.
Don't want the engine blowing up in my face. The weather is pretty warm here and I do change my oil every 3k miles... had nothing but 5w-20 in the engine and now I'm at 21,200 miles just about. 5w-20 always looked so thin... bleh. Re: Scorching summer heat: how many of you still use 5w20?
I have worked on camshaft design for Honda motor company for the last 16 years.
the 5w 20 oil specification is so that the variable valve timing will work correctly on the 2.4 L engine that was in a lot of the Honda Accord models. If you change the viscosity of the oil that you use you change the pressure that function to make this system work correctly.
thanks for the input, but... This thread is 19 years old, so if you could try to not revive very old threads...
