Best timing belt
Old Feb 19, 2024
Robertlx's Avatar
Robertlx is an unknown quantity at this point
Best timing belt
I'm probably going to get a kit that includes the timing belt, water pump and tensioner along with valve cover gasket and other boots and seals. But for my own piece of mind I would like to get the best timing belt separately. So in your opinion what make or whatever it's made of would you recommend.
Old Feb 19, 2024
BrotatoChip's Avatar
Super Moderator
Re: Best timing belt
GATES TCKWP312. Comes with timing belt, tensioner, spring, and water pump for under $100. I believe Gates was the manufacturer for the original timing belt.
Old Feb 19, 2024
Robertlx's Avatar
Alright I put that in the shopping cart from partsgeek.. I'm pretty sure I'm gonna want to have a valve cover gasket kit and the camshaft seal along with the crankshaft seal while everything is torn down for that..any suggestions for a good make.
Old Feb 19, 2024
FRSam's Avatar
Click Here
I went OEM Honda for mine but Felpro makes a good kit.
Old Feb 19, 2024
Robertlx's Avatar
I put felpro camshaft and crankshaft seals in a cart..is that good.
Old Feb 19, 2024
FRSam's Avatar
Click Here
That is fine.
Old Mar 16, 2024
Robertlx's Avatar
Finally got
it installed this morning. Took your advice and went Gates Timing Belt Kit.(these are the old parts)
Geyco
Dec 24, 2021 11:17 AM
whirlybird9
35
Apr 10, 2016 09:18 PM
Smythley
Feb 1, 2011 12:43 PM
Unevolved
32
May 30, 2010 12:24 AM
02civic21
Jun 4, 2007 07:03 PM
