wont start when wet, missfire, poor idle
Old Aug 13, 2023
ncc74656's Avatar
ncc74656 is an unknown quantity at this point
1.7 vtech. runs fine once warmed up. some times it will not GO but flooring it clears that problem.
when stopping if i go slow to the stop it will idle and stay. if i stop hard or let off hard it will drop VERY low rpm, try to catch itself and die.
after it rains, it wont start. takes quit a lot of cranking and then sits with miss fires for a while. only on 2/3/4 - 1 seems fine.
it was run hot for 5 months. driven with no coolant through the winter with temps pegged all the time.
it did this before and after rebuilding the engine so its a sensor? (all sensors and coil packs reused) thoughts?
no engine codes except knock sensor
Giberish33
Feb 16, 2021 06:25 AM
napkins
Aug 12, 2015 04:20 PM
raidermaniac
Mar 1, 2014 11:11 AM
GuiltySparq
Jun 2, 2012 12:21 AM
wikkaco0
Apr 6, 2008 08:53 PM
