Ring a ding dang a ramalama [case closed by OP]
Old Jul 18, 2022
crajnai's Avatar
7th Gen Victim
crajnai has a spectacular aura aboutcrajnai has a spectacular aura about
Ok. Look at my pistons. I can clearly see the markings. Valves are good. Doesn’t seem to be excessive carbon.
So do I do the rings?
Old Jul 18, 2022
FRSam's Avatar
Click Here
re: Ring a ding dang a ramalama [case closed by OP]
Depends on a variety of factors.
If it's an otherwise healthy engine, I would leave it alone.
If there's any notable oil consumption, it may be worth replacing them. Even then, maybe not.
Old Jul 18, 2022
crajnai's Avatar
7th Gen Victim
Depends on how we define healthy at 161k, but I haven’t had the car long enough to know wether it consumes oil or not. This is my conundrum. I sure don’t want the extra work, but I’ll be ding danged if I gotta crack this open again in the next 50k.
Old Jul 18, 2022
FRSam's Avatar
Click Here
I probably would, then. You're already down there.
Old Jul 18, 2022
crajnai's Avatar
7th Gen Victim
ALSO: there were no guide dowels when I took this head out. I will get two but any idea where they go?
Old Jul 19, 2022
BrotatoChip's Avatar
Super Moderator
They're not stuck to the head?
Old Jul 19, 2022
crajnai's Avatar
7th Gen Victim
Not on the head nor the block. I’m wondering if the lack of them contributed somewhat to the gasket failure. Misalignment?
Old Jul 19, 2022
Colin42's Avatar
Definitely could be part of the problem
Old Sep 18, 2022
crajnai's Avatar
7th Gen Victim
I did not replace the rings on this job. Check my other posts for how it worked out.
VTecnology
Dec 19, 2001 11:53 AM
