Oil Pan Leak
Old Nov 10, 2021
Hotion's Avatar
Hotion is an unknown quantity at this point
Oil Pan Leak
Was workin on my cooling system when i noticed oil everywhere on my pan/tranny. found out there’s a lot of oil coming from this pulley thing. Anyone know what this could be? / if it could be easy to DIY?
05 LX 1.7 D17A1
Old Nov 10, 2021
Colin42's Avatar
Re: Oil Pan Leak
Front crank seal or oil pan gasket. Oil pan gasket is relatively easy. Crank seal is a little more difficult because you have to remove the crank pulley
Old Nov 11, 2021
bachands's Avatar
bachands is just really nicebachands is just really nicebachands is just really nicebachands is just really nice
Re: Oil Pan Leak
I agree, it's probably the oil pan gasket or crank seal.
I used to have oil leakage from that same spot. I ended up replacing the oil pump-to-block o-ring (along with the crank seal and RTV oil pan gasket). Could this be the o-ring leak?
ramstein
Jan 24, 2014 09:41 AM
Nosepicker
17
Aug 25, 2010 11:02 AM
deathcab
Dec 7, 2005 06:30 PM
jpan_home
Mar 1, 2005 03:43 PM
CivicMexicano
Oct 21, 2004 06:58 PM
