Help! I can’t find timing marks....
Old Feb 1, 2021
Sean Anderson's Avatar
Sean civic dx
Sean Anderson is an unknown quantity at this point
I have a 01 civic dx and I’m doing a timing belt change and I can’t find the TDC arrow on the oil pump. Is there another mark somewhere else on the oil pump?
Old Feb 1, 2021
BrotatoChip's Avatar
Super Moderator
Re: Help! I can’t find timing marks....
You sure it's not hiding behind the belt? Reference picture below.
Old Feb 1, 2021
thetut's Avatar
thetut is a glorious beacon of lightthetut is a glorious beacon of lightthetut is a glorious beacon of lightthetut is a glorious beacon of lightthetut is a glorious beacon of lightthetut is a glorious beacon of light
The only timing marks are on the crankshaft and camshaft pulleys. Refer to this https://www.civicforums.com/forums/1...ne-timing.html
Old Feb 1, 2021
Super Moderator
There is a timing mark on the oil pump as well, you can see in the pic above. The arrow should line up with the line on the crank sprocket. The post you linked is checking timing with the lower timing cover and crankshaft pulley still installed.
Old Feb 2, 2021
Sean civic dx
If it’s behind the belt, is that normal for the belt to be covering it? And if I get the top pulley to TDC wouldn’t that line up the lower oil pump pulley?
Old Feb 2, 2021
Super Moderator
Been a while since I've done a timing belt on a 7th gen but I do kind of remember the arrow on the oil pump being behind the belt. Makes it a big more difficult to line up but still manageable.
If the camshaft sprocket marks are lined up to TDC then the line on the crank sprocket should match up with the arrow on the oil pump.
Old Feb 2, 2021
Sean civic dx
Ok so I found it.... it’s basically useless. Wtf am I supposed to with this. This has to be a joke the Honda engineers decided to play on dx owners.
Old Feb 3, 2021
Super Moderator
It's the same on all D17 engines. It's a bit inconvenient but you have to make it work. You could try using a permanent marker to extend the arrow or something.
MainFrame
Apr 4, 2018 09:44 PM
cukaracha
Mar 16, 2016 07:38 AM
clayhill
Sep 26, 2015 10:19 PM
sam68
Feb 10, 2011 09:08 AM
jdmplease
21
Feb 7, 2008 08:46 PM
