Piston rings installation order
Old Dec 30, 2019
tott2692002's Avatar
tott2692002 is an unknown quantity at this point
04 civic
bough the Honda piston rings. Beside the oil rings the other two rings one has 1A indentation and the other has R
which one goes on the very top ?
thanks
Old Jan 2, 2020
BrotatoChip's Avatar
Super Moderator
Re: Piston rings installation order
You have OEM rings?
The second ring is usually all black, the top ring is usually gray/silver. There should be some sort of mark on them, install that side up.
Old Jan 2, 2020
You have OEM rings?
Yes. It’s the Honda Rings
the marks are R on one and 1A on the other. I figured it out
the second one from is thicker the top one and only can fit in one place
thanks
Iron_Boarder
Oct 13, 2019 07:48 PM
qfroth
Apr 24, 2012 12:35 AM
josh.crotsley
May 20, 2011 12:37 AM
klapdout
Aug 29, 2005 01:35 PM
