Civic hybrid starts then dies
Old Jun 9, 2019
Zach Jones's Avatar
Zach Jones is an unknown quantity at this point
Hey how’s it going I have a 03 civic hybrid and everytime I first start it it rough idles for a sec and dies or it will just die I have to put my foot on the gas but after that it won’t die . I ran the codes and it has a misfire on every cylinder . And a random misfire . Anyone else have this problem ?thanks
Old Jun 9, 2019
Colin42's Avatar
Re: Civic hybrid starts then dies
If you leave the key on for like 30 seconds before you try to crank it does it start fine?
Old Jun 12, 2019
mac25's Avatar
Dr Krieger of Modification
Multiple misfires should rule out anything specific to one cylinder.
So it's probably not
-injectors
-coil packs
-plugs
-most likely since you need to give it more throttle and you have no air related codes, like IACV codes, its fuel delivery related.
Check ignition pulse at the injectors and fuel pressure at the rail.
If these check out do a generic once over
-grounds/battery connections
-fuses/relays
-check for strong spark at plugs (white/blue)
-and of course we've already checked fuel pressure at rail and injectors for pulse.
treehan
16
Oct 4, 2021 09:27 PM
kevin98208
18
Jan 4, 2017 08:10 PM
ksteak
May 31, 2009 02:06 PM
pcheruka
May 3, 2009 08:12 PM
