2002 civic dx sedan 1.7L burning oil
I seem to have to add a quart or so a week. I changed the valve cover gasket/valve seals and all that which was leaking before and confirmed not leaking there after doing the job. No oil leaks on to the ground. This car has 233,000km on it. I noticed if i hit the gas hard on it a little blue/black smoke will puff out, none at idle or regular driving. This cars engine runs phenomenal and the car is generally in great shape for its age. The car sat for a few months in the owners driveway before i bought it.
Could it be a pcv valve? Stuck piston rings? Also no oil in coolant and no coolant in the oil.
I ordered a pcv valve for the hell of it as they were only a few bucks. Also changed oil filter, air filter, spark plugs, cabin filters..tried lucas fuel treatment and oil treatment and no change was noticed. Any help would be appreciated!
Re: 2002 civic dx sedan 1.7L burning oil
the oil rings are probably stuck, you can re-ring the engine with the engine still in the car
what oil are you using? you can try switching to a good 0w20 synthetic oil and it may help reduce the burning.
I noticed an improvement in my old car, but my burning wasn't as bad as yours
remove head, remove oil pan, remove pistons.
should be able to find head and oil pan videos, or there's diy articles for those on here, there's also a link for a pdf copy of the service manual as well.
replace the head gasket, timing belt, tensioner, and water pump while you have it all apart. use oem honda parts
Sounds exactly like your oil control rings have been clogged up with sludge which then further cooks into concrete like rock.
I played around with different chemicals trying to clean mine, but still ended up using toothpick and toothbrush to clean out every little crevice.
Imagine ring of bent steel that looks like “WWWWWWWWWWWWW” all the way around with concrete stuck all inside it.
That experience is why I believe the more additives you have in the oil such as high mileage oils the more likely this occurs because I was using chemicals that dissolve normal carbon and my rings were still full of large particles of “something else”.
Also, your killing you catalytic converter by dumping that much oil into it.
That is true for burning due to heat, especially for boosted and high compression engines, but not for burning oil due to worn parts.
A 0w20 oil us far thinner than a 5w20 when cold. So if the valve seals are leaking over night, 0w20 would leak worse.
The right direction to go is thicker.
-5w20 high milage
-5w30 high mileage
-10w30 high mileage
-10w30 high mileage with stop leak/burn
-5w20 high milage
-5w30 high mileage
-10w30 high mileage
-5w20 high milage
-5w30 high mileage
-10w30 high mileage
abrahamtennyson
May 30, 2017 10:10 PM
ivy7845
Dec 8, 2011 06:28 AM
sik92civic
Feb 18, 2010 07:00 PM
