Exhaust Leak: Headers -> A Pipe
Old Jan 7, 2019
iSamoStefan's Avatar
iSamoStefan is an unknown quantity at this point
I put a new crush gasket in and new bolts (OEM) but the leak is still bad. Lots of soapy bubbles at the joint.
Assuming the spring bolts are working (i.e. tightened evenly), what am I looking at for a fix?
A in the illustration is NOT leaking.
D in the illustration is LEAKING.
Old Jan 7, 2019
Colin42's Avatar
Re: Exhaust Leak: Headers -> A Pipe
Is it an OEM gasket?
Old Jan 7, 2019
Yes it is
Old Jan 7, 2019
GolNat's Avatar
Prelude Owner
Something not lined up causing the gasket to not seal properly. Check flanges for any obstructions. Is it the correct gasket?
Old Jan 7, 2019
Yes it's the correct gasket, it actually sealed like 90% better than the Flepro one I tried first.
Old Jan 7, 2019
GolNat's Avatar
Prelude Owner
Yea Felpro is more miss then hit OEM is best.
Is something bent?
Old Jan 7, 2019
Is something bent?
It's beyond me if the headers or the downpipe mating surfaces are bent? That would suck
Old Jan 7, 2019
Colin42's Avatar
Take a straight edge to it
Old Jan 8, 2019
It's not a straight application though.. it is concaved allowing for the doughnut gasket to press up inside there.
Old Jan 8, 2019
Colin42's Avatar
but the flanges should be straight
Old Jan 8, 2019
They don't even touch though but yeah for the spring bolts to be able to work maybe. What is your rationale to making sure the flange lips are straight if I may ask?
Old Jan 8, 2019
Colin42's Avatar
even clamping pressure
Old Jan 8, 2019
Ok let's fast forward and assume that they are bent to ****. Now what? I do own several hammers.
Old Jan 8, 2019
Colin42's Avatar
Get them as straight as you can, grab another gasket and see what that gets you
Old Jan 8, 2019
Alright, well that solves next steps. I will come out and say I lied, I am using random spring bolts off the shelf from Advanced Auto. The new OEM ones will arrive at Honda on Thursday. Gonna try those first and straight edge while i'm in there... again. These bolts wear out so fast.
Old Jan 8, 2019
Slumpertcivic's Avatar
Whaaaaa?
How often are you pulling the pipes off?
Old Jan 8, 2019
Originally Posted by Slumpertcivic
Whaaaaa?
Just like 4 times in the past 5 years, but they get so burnt and the threads start to suck ***
HarleyRob
Oct 27, 2018 08:42 AM
boosted.es2
Mar 4, 2007 07:06 AM
quwok
Feb 10, 2006 05:37 PM
D5cIvIc
Jan 27, 2006 06:27 PM
SpeedFreak
Mar 25, 2005 10:43 AM
