2001 Honda Civic EX 4 Door oil leaking problem
Old Nov 20, 2018
Mirquhl's Avatar
Mirquhl is an unknown quantity at this point
Question 2001 Honda Civic EX 4 Door oil leaking problem
Hey hope I'm in the right section, I have a oil leak and cant find out where it is coming from?
My Honda Civic has burnt oil all over and leaking oil too.
Do any of you guys have an idea or suggestions where the oil is coming from?
100% VTEC solenoid is leaking has bubbles.
Can that oil leak reach and produce that much of an oil leak?
Sorry if pictures are dark
Old Nov 20, 2018
GolNat's Avatar
Prelude Owner
Re: 2001 Honda Civic EX 4 Door oil leaking problem
VTEC solenoid is a common place they can make a mess. So is the cam seal plug (side of head where the cam is at).
Old Nov 20, 2018
Mirquhl's Avatar
Cam seal plug has no leak recently replaced any other suggestions?
Old Nov 21, 2018
Slumpertcivic's Avatar
That transmission mount seems blown, it comes preloaded with hydraulic fluid that might have spewed out.
Hows your automatic transmission fluid level doing?
While that may seem like a huge leak, just a few ounces of oil will have a similar result.
Old Nov 21, 2018
Mirquhl's Avatar
Transmission fluid not low looks good.
Old Nov 21, 2018
Colin42's Avatar
so you know the vtec solenoid is leaking, replace the gaskets, clean up the engine bay real good and see if there are any other leaks
Old Nov 21, 2018
Mirquhl's Avatar
Okay I'll try that also, could it be the oil pan or rear crankshaft main seal?
Old Nov 21, 2018
Wankenstein's Avatar
The oil shown in your pics are not from the oil pan or rear main seal..as oil would not leak up, only down.
Old Nov 21, 2018
Colin42's Avatar
not in those pictures
Originally Posted by HR Puffinblunts
oil does not leak up, only down.
Old Nov 21, 2018
Mirquhl's Avatar
Buddy told me according to pictures could be because air will force oil back and forth is this true?
Old Nov 21, 2018
Not in this case. It's oil leaking down. In the case of a torn CV boot grease can jizz all over the place but that's due to the rotation of the axle.
Old Nov 21, 2018
Mirquhl's Avatar
Okay I ordered VTEC solenoid gasket going to replace hopefully fixed cant think of anything else could be causing it
Old Nov 22, 2018
Colin42's Avatar
there's 2 gaskets, did you get both of them?
Old Nov 22, 2018
Mirquhl's Avatar
Yes I did
Old Dec 20, 2018
04civicexx's Avatar
04civicexx is an unknown quantity at this point
Did this work bc I think I have the same leak
Old Dec 20, 2018
Mirquhl's Avatar
Yes worked for me not leaking anymore
04civicexx
Dec 21, 2018 07:32 AM
LionSpratt
Jan 29, 2017 11:07 PM
iliketogetdirty
Apr 11, 2016 11:08 PM
x3ro
25
Apr 11, 2012 09:00 AM
civic2000abc
Jul 31, 2010 10:13 PM
