2002 honda civix lx po336 code help need fix
I have replaced the crankshaft position sensor, car ran great for a day and now it starts weird and the ecu set its own limit at 3500 Rpms please help[YOUTUBE]https://www.youtube.com/watch?v=aGUFkeFROSM&feature=youtube_gdata_player[/YOUTUBE]
Re: 2002 honda civix lx po336 code help need fix
P0336 is CKP (crankshaft) sensor intermittent interruption
You still have the old sensor?
Get a flashlight and look in the connector area and see if there is any corrosion on any of the metal terminals. If there is, then there is probably identical corrosion on the wiring harness on the engine that will need fixed.
CarStuff
Dec 6, 2020 12:52 PM
jessicakaybby
Apr 20, 2015 12:11 PM
Bartkat
20
Feb 19, 2002 01:29 PM
