OMG car wont start! need immediate help
i know it happened after i took out the viper alarm, and i know its related to the ignition wires around the steering column i cut, but i dont know what to do to make it start. there was a yellow wire that i already had cut long time ago to disable auto locking, but i also cut a tiny 4wire combo wire and taped it off that was coming from the alarm, and also a green and black thick wire. i need to know asap what i should do with one or more wires to make it start. i dont understand this because the alarm was disconnected a long time ago already. my only guess is i need to connect wires together or something. i need my car for work tomorrow and its already late. im about to head back out but i have no idea wtf to do.
Live for the Twisties
Re: OMG car wont start! need immediate help
Dude, your having a bad day.
I'd suspect the green and black wires need to be reconnected, go re-connect them and I bet it will start, if not you've eliminated one of only a few possibilities so it's not an exercise in futility.
yeah you were right. i took the old harness out of the trash and the two thick wires went to the starter kill relay. im guessing that since the relay was connected before, it still lets the car start even if the alarm is unplugged. i traced back to the ignition, and sure enough it led to the same starter wire. circuit city had used jb weld putty on the wires, so i redid everything with an extension wire and soldered both sides. after an hour later of fixing and taping, everything is good as new lol. so i guess it worked out and now the connection is better than before. took it for a drive and so far everything is normal. next i add some dynamat to the door panels to cover the holes now that i fixed the door lock actuator. that should be easy tho heh.
CarStuff
Dec 6, 2020 12:52 PM
SSMatey
Apr 13, 2015 06:09 PM
