What else is needed for Timming Belt change?
Old Sep 25, 2006
i5r's Avatar
i5r
i5r is an unknown quantity at this point
flame suit ON!
Its time for timming belt change, but should i be changing anything along with it? someone told me water pump or somthing too
Old Sep 25, 2006
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
(not saying that i due.. but)
yer willing to take on a timming belt.. but you dont know what else usuially gets changed out at this time as well...... for some reason im scared for you...
anyway... here.. straight from honda.. reccomended 60k maintineance
http://img.photobucket.com/albums/v2.../car/mait2.jpg
Old Sep 26, 2006
streetglower's Avatar
what I did and I would recommend too is to replace the valve cover gasket and spark plug tube seals, both drive belts, water pump, timing belt tensioner, crank pulley, cam and crank seals (I didnt do those cause I forgot). it seems like alot but everything I replaced came off during the change so I replaced it. the tensioner never came off but I wont risk using an old one and having it fail soon after.
Old Sep 26, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
why change the crank pulley & cam street?
just because they came off???
Old Sep 26, 2006
dariusld's Avatar
dariusld is an unknown quantity at this point
http://www.7thgencivic.com/forums/sh...highlight=belt
Some timing belt threads, if you haven't already read them. Pay close attention to my replies
Old Sep 26, 2006
just the crank pulley. because over time the rubber on the balancer deteriorates. it may not be bad, but at $60 or so, I went ahead and did it. I also meant the cam seal.
Old Sep 26, 2006
02BLKCIVIC's Avatar
OOOOOOOOOOOOOO
ok.
mattdoc
Mar 14, 2017 12:10 PM
slynger
18
May 8, 2015 06:06 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
CivicVoz
Apr 16, 2015 08:07 PM
Myredjonda
Apr 14, 2015 07:00 PM
